Scott H |
Luddite ![]() ![]() Group: Members Posts: 81 Joined: 12-September 05 From: Gastonia, North Carolina, USA Member No.: 4,790 ![]() |
I have a '72 that's been parked since back around '85. I'm using this car as a learning tool to learn my way around a 914.
The PO gave up on the car while in the middle of converting it to carbs and just let the car sit and rot away. He had bought a Bursch exhaust at the time that he said he thought was the wrong one and he never got around to exchanging it for the correct one. This exhaust has been sitting inside the car all that time and was never even bolted onto the car. The exhaust has a sticker on it that says "914 73-74" and I see that Pelican Parts sells '70-'72 and '73-'74 Bursch exhausts so it looks like it is indeed the latter and the wrong one for a '72 (I'm sharp today (IMG:style_emoticons/default/biggrin.gif) ). Pelican only shows a picture of one exhaust. My question is: what's the difference between the two? If I hold this exhaust up to the ends of the heat exhangers it appears that it will bolt up. The rear valence is not on the car, so it looks to me like the tip of the exhaust would hit the valence if it were in place. Is that the only difference between the two? If it helps, here are some pictures of the one I have: http://smg.photobucket.com/albums/v134/sdc...rsch%20exhaust/ Thanks for any help. **edit: I didn't notice the other Bursch topic until after I posted mine. If a moderator wants to move my post over there, that's fine by me. |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
the 70-72 obviously is for a 1.7 - with a porthole valence, so the exhaust tip is routed down a bit more and a bit more to the middle of the car. If it is a 73-74 (1.7) the exhaust tip is moved more to the drivers side and up for the shorter notched valence. If it was a 73-74 with a 2.0 the flanges that mate up to the heat exchangers will be lower, but the exhaust tip will be the same as the 73-74 1.7.
Lo-Fi Version | Time is now: 2nd July 2025 - 07:55 AM |
