A-arm bushings, can they be removed ..., without destroying them, to reuse them? |
ein 6er |
Oct 31 2006, 04:19 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
i want to powder coat my a-arms, and polybronze or needles aren't in the budget, (and don't want the plastic ones).
BTW, these are low mile '86 carrera arms, i've had them in storage for about .... 20 yrs, time to use them. thanks!! |
ein 6er |
Nov 1 2006, 06:54 PM
thanx everybody!!
i guess i'll just paint them, for now. pt, you can get just the bushings, polygraphite, for about $40, but i think they take some work to get them to fit, and it's recommended to cut some grooves to get grease in them. chris foley sells delrin bushings pressed into the mounts with grease fittings for $295. a set. the polybronze are about $240 from elephant racing. here is a link to pelican. and i can't find seem to find any info on the roller bearings. hope this helps. |
ptravnic |
Nov 2 2006, 07:06 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
thanx everybody!! i guess i'll just paint them, for now. pt, you can get just the bushings, polygraphite, for about $40, but i think they take some work to get them to fit, and it's recommended to cut some grooves to get grease in them. chris foley sells delrin bushings pressed into the mounts with grease fittings for $295. a set. the polybronze are about $240 from elephant racing. here is a link to pelican. and i can't find seem to find any info on the roller bearings. hope this helps. Thanks for the feedback. -pt |
Lo-Fi Version | Time is now: 11th June 2024 - 03:34 AM |
