Carbs - which distributor?, Swapping out FI, trying out carbs |
ptravnic |
Nov 3 2006, 09:08 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I'm looking to put on a set of carbs for ease of bench testing/engine swapping. The car I'm swapping systems on has been running D-Jet. What type of distributor will be needed ?
My carb options are Webber 44's, Dellorto 40's, and a set of Solex that I'm not sure of the size off hand. I have these carbs on hand, just need cleaned up. Thanks in advance! -pt |
ptravnic |
Nov 3 2006, 10:22 AM
Thanks guys. For some reason I thought that carbs required a diff distributor. Maybe that thought got crossed with fuel pump. I've got a couple low pressure fuel pumps that will work out.
And don't worry, I'm not throwing away the FI completely - just planning on doing a few engine swaps between 3 diff cars and want to make sure I can get them tuned & driveable during the benchtest's. It seems to take me quite a bit of time to get all the FI stuff sorted when swapping in/out engines. whereas carbs are a couple bolts and that's it. -pt |
Lo-Fi Version | Time is now: 9th June 2024 - 12:15 AM |
