Rust removal : any experience out there ? |
jsteele22 |
Nov 5 2006, 04:37 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
So the engine/tranny are out of my car and I cleaned the engine bay out reasonably well. Very little rust in general, but of course the RH hell hole was pretty funky. And the battery tray was half gone, so I removed the tray and the support. Today I attacked it with a wire brush wheel in a power drill. I found that the flaked paint (if any) came off pretty fast, then a layer of light brown dry powdery rust also came off reasonably fast. After that, I seemed to get to a layer of "lumpy" kooking metal that would take on a burnished look, but the color was more of a dark grey than the shiny silver I expected. If I brushed where there had been no rust, I did find shiny silver. So what I want to know is : how far should I go ? It feels like I'm gonna have to remove a lot of material (and spend forever doing it) if I try to procede w/ the wire brush. I don't have air tools, so blasting would take a lot of effort to set up, and I'm sure it's a big mess. Is media blasting the only way to procede ? OTOH, if I get all the metal down to that lumpy, dark grey, burnished state, will one of those rust converter products be good enough ? There realy isn't that large an area affected, and so far it doesn't look like there are any "rust throughs" or structural issues. Sorry, no pics yet. Car at home, camera & computer at office, not organized enough, etc. I'll see if I can get a well-lit pic in the next day or so. |
scotty b |
Nov 5 2006, 04:55 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
When you hit the "lumpy metal" you really should go at it with a flatblade screwdriver and a hammer. Tap the screwdriuver at an angle to try at get under the lump, usually it will pop off and you will have a hole underneath. As for the treatment use ONLY Ospho or another similar product (phosphoric acid based) the "rust converters) sold at fLAPS are not true converters and will only make you feel better. When using a phosphoric based product
USE RESPIRATORY PROTECTION AND SKIN PROTECTION!! Got that? Phosphoric acid is N-A-S-T-Y stuff and will f-you up if inhaled! Don't let that scare you off just be cautious. I regularly spray it into rocker panels and other areas I can't access just as a safety measure and have gagged to the point I had to walk far away from the fumes. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:39 AM |
