rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 521 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
I had to dynamite the brakes to save myself, or my car, the other day and the engine died. It easily restarted, air temp was 40 degrees or so, then I hit the brakes again with the same response. I thought maybe its happening due to temp but it was 60 yesterday and the same thing happened. It had never happened before tha first incident and I'm perplexed as to why it is now happening. It otherwise runs great and I hanen't done anything recently that should cause this to happen.
Any ideas? thanks, jule |
rudedude |
Thanks for the suggestions!
I've never had any problems under hard cornering. The float chambers have been drilled. I forgot to mention it has a 2.7 with s cams je 9.5 pistons but I dont think the mods are a problem.I'll look at connections, maybe I'll have to fill the tank. Thanks, jule |
Lo-Fi Version | Time is now: 4th July 2025 - 11:37 AM |
