Mini-starter goes "ping!", What the hell. |
LowGT |
Oct 9 2006, 11:12 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
So I swapped to a 2.0 and a new mini-starter and everything has been starting fine for the last two weeks. I went to tune the carbs last night and it started fine. After the car warmed up I shut it off to remove the carb linkage. (I think it's easier to adjust this way) When I tried to start it, all I got was a loud "ping".
I checked the battery and it was a bit low. I charged it all night and no difference, so I bought a new battery. Still only got the ping. So I check and clean all grounds, checked the voltage regulator wiring. Everything is in tip-top shape. Tried it start, PING! All the gauge lights dim like maybe the starter will turn, but it never does. I tried turning the engine by hand and it turns fine. It sounds like the starter gear is just coming out and hitting the flywheel, and never turning. Any ideas? |
Dr Evil |
Nov 8 2006, 12:56 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
No. If you are hearing a ping then it is trying to extend the bendix drive but is not able to all of the way. Something is obstructing it. Check your engine to tranny bolts to make sure they are all tightened and that the case is not cocked.
Lo-Fi Version | Time is now: 7th June 2024 - 10:48 AM |
