Mini-starter goes "ping!", What the hell. |
LowGT |
Oct 9 2006, 11:12 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
So I swapped to a 2.0 and a new mini-starter and everything has been starting fine for the last two weeks. I went to tune the carbs last night and it started fine. After the car warmed up I shut it off to remove the carb linkage. (I think it's easier to adjust this way) When I tried to start it, all I got was a loud "ping".
I checked the battery and it was a bit low. I charged it all night and no difference, so I bought a new battery. Still only got the ping. So I check and clean all grounds, checked the voltage regulator wiring. Everything is in tip-top shape. Tried it start, PING! All the gauge lights dim like maybe the starter will turn, but it never does. I tried turning the engine by hand and it turns fine. It sounds like the starter gear is just coming out and hitting the flywheel, and never turning. Any ideas? |
LowGT |
Nov 9 2006, 02:19 AM
Ok, here's my list so far:
Tranny is flush to engine, all bolts tight. Flywheel is not noticably loose. The teeth on the flywheel are a worn a little, but I've had it on 2 other engines and this one with no problem until the mini-starter. Now the problem is affecting my stock starter as well, which previously worked fine unless it was hot. I ran a straight edge over the mating surface between the starter and tranny. The case isn't warped, bent, or cracked. I tried different combinations of shims between the starter and the tranny case, nothing worked. I've rotated the engine manually while trying the starter and it still won't engage the flywheel. I've rotated the flywheel to try starting in different spots. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:54 PM |
