Mini-starter goes "ping!", What the hell. |
LowGT |
Oct 9 2006, 11:12 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
So I swapped to a 2.0 and a new mini-starter and everything has been starting fine for the last two weeks. I went to tune the carbs last night and it started fine. After the car warmed up I shut it off to remove the carb linkage. (I think it's easier to adjust this way) When I tried to start it, all I got was a loud "ping".
I checked the battery and it was a bit low. I charged it all night and no difference, so I bought a new battery. Still only got the ping. So I check and clean all grounds, checked the voltage regulator wiring. Everything is in tip-top shape. Tried it start, PING! All the gauge lights dim like maybe the starter will turn, but it never does. I tried turning the engine by hand and it turns fine. It sounds like the starter gear is just coming out and hitting the flywheel, and never turning. Any ideas? |
Joe Ricard |
Nov 9 2006, 06:04 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Put some white grease or paint on the gear teeth and face of / side of flywheel. then try it take off the starter and see whats going PING!!!
Lo-Fi Version | Time is now: 8th June 2024 - 12:33 AM |
