> Optima Battery Failures?, Having trouble
TravisNeff
post Nov 13 2006, 05:06 PM
My car hasn't been started in several months, which has a Optima red battery in it. Electricals work, but the starter will not engage. I popped my battery on the charger for a while and it shows that it has a full charge. Still have the same starting issue, it could be the starter - but I guess I will ask if these batteries can lose cells like a conventional one. I'd hate to shell out $140 and find out that is not my problem. How can I check this, check power at the terminals with a DVM while someone turns the key??
gregrobbins
post Nov 13 2006, 07:02 PM
Member: Team NARP
Can you trickle charge an OPTIMA? Solar card charger?
Yes, you can use any charger on an OPTIMA as long as the voltage is regulated properly. If your charger will remain on indefinitely the voltage should be at 13.8 volts maximum with a one amp maximum current.
This is a quote from the Optima web site. AZBill put his on a regular charger and "cooked" it.
- Lo-Fi Version Time is now: 8th July 2025 - 09:18 PM
