Wellp, it finally happened, Driver's Side Outside Door Handle Failure |
Brando |
Nov 22 2006, 09:02 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
It was only a matter of time. Thing locks difficulty, will barely unluck and won't open from the outside. Between this and the master/slave clutch cylinders on my 944 going south, I finally have things I can do simply on my cars. Does anyone make repro plastic pieces that go over the door handle to actuate the opening lever in the door yet?
URY914 |
Nov 23 2006, 08:15 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've seen the new black plastic sliders fail if you don't keep things clean and lubed. The problem with the new ones is they bend without breaking. So you go to all the trouble of taking the handle off and it looks good, but doen't work when installed.
Lesson learned: Keep it clean, lubed and use it..... (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:15 PM |
