> Recommended 914 Suspension Matrix???, Do "we" have one???
Mueller
post Nov 7 2003, 12:15 PM
914 Freak!
I'm looking for a table that would have the following proven and or tested setups:
Component
StockStreetAuto-XRace
Torsion Bars (mm)XXmmXXmmXXmm
Rear Springs (lbs)XXXXXXXXXXXX
Of course, much more info needs to be added with comments and warnings about teeth rattling out or oversteer/understeer
Qarl
post Nov 7 2003, 01:20 PM
Shriveled member
Mueller... sloppy work as usual. Get with the program.
I surmise that the end result of this table is that needle bearings will be in every cell of this table????
I do see, however, that this table could raise a lot of controversy. Everyone has their own opinion and there ARE many factors to consider.
Perhaps, multilple suggestions or ranges of suggestions for each category may be appropriate.
Explanations, notes, comments, etc. would also be helpful.
For example.. street 914.. rear spring values could be 100# to 140# and maybe explain what would influence one rate vs. the other.
I recall seeing some torsion bar vs. spring tables on a thread 6 months or so ago.
mmmm.... Springs... (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif)
Mueller   Recommended 914 Suspension Matrix???   Nov 7 2003, 12:15 PM
Qarl   I think the following additional information would...   Nov 7 2003, 12:31 PM
Mueller   ditto :) Do you think a simple table would be fin...   Nov 7 2003, 12:35 PM
fiid   we need a brake matrix too. 23mm fronts for a tra...   Nov 7 2003, 12:39 PM
J P Stein   If you're looking for input, I'd say that ...   Nov 7 2003, 12:46 PM
Jeroen   Maybe you should add a swaybar row to the table Ad...   Nov 7 2003, 12:50 PM
brant   I agree with JP regarding the rear rates... but it...   Nov 7 2003, 12:54 PM
Mueller   just to let everyone know......my table is just th...   Nov 7 2003, 01:13 PM
J P Stein   Brant is right bout the tire thingy. You should as...   Nov 7 2003, 01:18 PM
Qarl   Mueller... sloppy work as usual. Get with the prog...   Nov 7 2003, 01:20 PM
J P Stein     Nov 7 2003, 01:38 PM
Brad Roberts   This doesnt work. You have to speak to the invidua...   Nov 7 2003, 01:43 PM
Qarl
  Nov 7 2003, 01:56 PM
J P Stein   I disagree, Brad. Many folks don't want to rac...   Nov 7 2003, 02:00 PM
mike_the_man   Wouldn't people with bigger balls want a cushi...   Nov 7 2003, 02:01 PM
Mueller
  Nov 7 2003, 02:03 PM
Brad Roberts   I want to help you... but I also want you to work ...   Nov 7 2003, 02:11 PM
GWN7   I like the idea of a matrix. It would give persons...   Nov 7 2003, 02:12 PM
Brad Roberts   A table showing the options is good. A table telli...   Nov 7 2003, 02:14 PM
J P Stein   Ok, here is my experience. Stock set-up....wienni...   Nov 7 2003, 02:54 PM
TimT   I started this season on 650# and 600# springs :bo...   Nov 7 2003, 04:45 PM
redshift   Cool! I tried to reply to this message... POW...   Nov 7 2003, 05:14 PM
Mueller   Tim, here you go: Bigger balls !!!...   Nov 7 2003, 05:20 PM
redshift   heh You should dress up like Neo, and fly out her...   Nov 7 2003, 05:23 PM
Joe Ricard   Wasn't there a thread last week about torquein...   Nov 7 2003, 06:17 PM
URY914   Automotion put out a little book in the '80...   Nov 7 2003, 06:58 PM
URY914   Let me try this...   Nov 7 2003, 07:29 PM
URY914   page 2   Nov 7 2003, 07:32 PM
URY914   Page three   Nov 7 2003, 07:35 PM
URY914   If Tom Green comes looking for me for this, tell h...   Nov 7 2003, 07:35 PM
SirAndy   <...   Nov 8 2003, 04:01 AM
Rob Ways   I agree with Brad that there is no ideal setup. Th...   Nov 8 2003, 08:18 AM
redshift     Nov 8 2003, 12:33 PM
Howard R   I agree with Mueller and JP. I can't see any ...   Nov 8 2003, 01:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:45 PM
