| Qarl |
Nov 7 2003, 06:42 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Okay... I'm starting my strut assembly.
1. First I'm going to insert a new upper strut housing seal - easy to. 2. Next I will insert the strut cartidge in and slide it all the way down so that I can see the curved end through the roll-pin hole. Question... - Should I lubricate anything on the inside of the strut housing and/or should I apply lubricant on the cartidge anywhere (i.e., should I lube my shaft?).... huh huh huh... I said lube my shaft. If so, where? and what kind of lube? (don't say KY or Jergen's!!!!!) 3. Next will go on the cooling ducts in place of the brake shield. 4. I will also assemble the hub to the rotor (rear bearings and seal already installed and lubed with Mobil 1 synthetic bearing grease). 5. Slide the rotor/hub assembly on to the spindle. 6. Pack the front bearings with grease and slide the outer race/bearing assembly onto the spindle. 7. Insert the thrust washer 8. Thread on the the clamping nut and and adjust the bearing freeplay. 9. Tighten the clamping nut hex screw. 10. Replace grease cap. Am I missing anything? (IMG:http://www.my914-6.com/images/dscn2059.jpg) |
| Qarl |
Nov 7 2003, 06:44 PM
One more question...
When I removed the old strut cartridges, there was no rubber snubber/bumper on the bottom. The new inserts have it. I assume I SHOULD install this in case the strut bottoms out. Is this correct? (IMG:http://www.my914-6.com/images/dscn2058.jpg) |
Qarl Strut assembly help... Nov 7 2003, 06:42 PM
TimT Karl I recommend you box all that stuff up and sen... Nov 7 2003, 06:45 PM
TimT If your going to really lower your car, cut down t... Nov 7 2003, 06:46 PM
kwales Kelley,
I can get KY for you by the case.... I w... Nov 7 2003, 06:47 PM
Qarl
TimT My car is low, I am using the same front struts as... Nov 7 2003, 06:51 PM
ChrisReale I am rather fond of Cocoa Butter myself. Oh wait.... Nov 7 2003, 06:57 PM
TimT Use anti-freeze with the Konis, the oil etc. sits... Nov 7 2003, 07:00 PM
Qarl Okay, I found the answer I was looking for on the ... Nov 7 2003, 07:04 PM
Qarl Okay... so do I lube the inside of the strut housi... Nov 7 2003, 07:04 PM
ChrisReale So, could one reason whhy I cannot get my front en... Nov 7 2003, 07:08 PM
J P Stein Karl, you'll want to lube the inside of the ho... Nov 7 2003, 10:33 PM
Qarl Thanks JP...
Here's the result... Nov 7 2003, 11:25 PM
Qarl Brake cooling duct on rear.
I also installed a ... Nov 7 2003, 11:27 PM
rhodyguy karl, your parts list would leave my checking acco... Nov 8 2003, 08:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:16 PM |
