| seanery |
Mar 7 2003, 01:19 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Hey guys, I'm taking a welding class at one of the local high school adult education centers. I've wanted to do this for a while and for some reason could never convince my mechanic to teach me. We use a Miller 300 (?) that is setup for Mig & Stick. Right now I'm learning stick. I actually made a couple of nice looking welds last night. I want to get a setup for home and don't really know what to get. The rig we are using is way too expensive. I've seen a Lincoln 225 stick only setup for $310 or so on ebay from a guy here in Indy. That would work for most stuff, but I'm sure I'm gonna want to learn to Mig and or tig sometime, too.
What do you guys use and how do you use it (what projects do you do)? Oh and I'm thinking about an auto darkening helmet. I hate being blind til I strike the arc. Anyone use a Miller Hobart XLix ? Thanks! |
| mr914 |
Mar 9 2003, 10:45 AM
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I have a Miller 150, 220V
What you have to be careful of the cheaper 110v migs is that the wire is always hot(engergized) all of the time. Which is basicly a pain as you are putting the gun close to your work and accidently touch the metal and get a spark. (LCD welding hemet is a work around though) The other problem with the smaller 110v migs is the duty cycle. Some of them are as little as 10%. In other words, weld for 6 minutes an hour. Which is very frustrating when you are trying to weld in a chasis stiffening kit. As far as LCD welding helmets, beware of the cheap ones! Some are fail light- as in, if it has a problem, it will go into the lighten mode, which is bad if you are in the process of welding. You are better off to have the model that is fail darken. Also check the sensor arrangement on the helmet. Some of them have two sensors and to darken both sensors need to sense light. If one sensor gets blocked the lens will lighten. A welding helmet is just like a crash helmet. If you have a $10 head wear a $10 helmet... |
seanery Welders Mar 7 2003, 01:19 PM
J P Stein I borrowed a Lincoln 110v MIG rig from a buddy....... Mar 7 2003, 01:42 PM
seanery After I get stick down, is MIG easy to learn? Mar 7 2003, 01:55 PM
airsix I have a Hobart Hander 135 MIG. It's great. ... Mar 7 2003, 02:00 PM
cha914 MIG will be a piece of cake after you learn stick.... Mar 7 2003, 02:09 PM
Lawrence914-6 I was really lucky, and stumbled on a rental shop ... Mar 7 2003, 02:14 PM
Gint Millermatic 175 I didn't want to have to buy ... Mar 7 2003, 02:39 PM
jdogg Santa Claus brought me a Daytona Mig 888 combi thi... Mar 7 2003, 03:07 PM
MJHanna The helmet is the best thing I have purchased for ... Mar 7 2003, 03:18 PM
Mueller Welding thick material is fine, but with our cars,... Mar 7 2003, 03:48 PM
airsix I'll add that I'd go for a 135 Miller or H... Mar 7 2003, 03:56 PM
Bleyseng If you are just doing cars and light metal you can... Mar 7 2003, 04:34 PM
TimT I have a craftsman mig, Its probably made by lincp... Mar 7 2003, 04:40 PM
Mike T I bought a Campbell-Hausfeld MIG105 wire feed. 120... Mar 7 2003, 05:00 PM
rick 918-S I have a Snap-On (made for them by Century) mig we... Mar 7 2003, 05:20 PM
seanery Thanks for the info guys.
I'm thinking about ... Mar 7 2003, 08:08 PM
ss6 I've got a Lincoln 175 MIG, but you won't ... Mar 7 2003, 08:43 PM
mskala I picked up a Campbell-Hausfeld flux/mig 80 off eb... Mar 7 2003, 09:16 PM
Gint
seanery I started MIG welding tonite!
WOOHOO!... Mar 27 2003, 09:10 PM
yoh!!! MIG - shielded gas.
The flux core stuff is a mes... Mar 27 2003, 11:15 PM
jdogg The gas is so much nicer to weld with. Quieter and... Mar 28 2003, 07:57 AM
MJHanna True but if you need to weld thicker material the ... Mar 28 2003, 08:16 AM
seanery I guess I could get both, huh?
A couple bottles an... Mar 28 2003, 08:28 AM
Bleyseng Just get a bottle that is about 48" tall as it wil... Mar 29 2003, 09:52 AM
seanery getting a miller automatic on monday-it's the ... Mar 29 2003, 06:44 PM
L8Apex I got the Hobart 135 115v MIG welder. It's aw... Mar 30 2003, 02:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:18 PM |
