> FI programming geek question, what chips do they use?
need4speed
post Nov 10 2003, 02:22 PM
I'm still a drooler, but I may have my first 914 in a couple of weeks if things work out.
And I'm already dreaming of building my own FI system (though the car I'm looking at is a 1.8 with what the owner says is a good, working L-Jet system).
And I'm wondering - has anybody ever seen an FI brain that uses an FPGA chip, instead of a regular chip designed for the task?
A buddy of mine works at Xylinx, and he explained to me about these FPGA chips - mostly used in routers and stuff - it's basically a big array of programmable gates, and you can load a program on by physically configuring the gates a certain way, and then, instead of loading software in to run on the chip - the chip works as if it's a custom designed IC. I kind of thought I'd like to try using something like this - I'm not a really experienced programmer, but I have worked with computers for 12 years, and I've always wanted to take on a project like this.
Any thoughts?
Mueller
post Nov 10 2003, 02:41 PM
914 Freak!
it sounds like a PLC but much smaller than the norm, not enough resolution if everything is either on or off
need4speed   FI programming geek question   Nov 10 2003, 02:22 PM
fiid   Most of everything built these days has a full-on ...   Nov 10 2003, 02:38 PM
Mueller   it sounds like a PLC but much smaller than the nor...   Nov 10 2003, 02:41 PM
SirAndy     Nov 10 2003, 02:59 PM
fiid   FPUs are for wusses. :-) You're right the CPU...   Nov 10 2003, 03:58 PM
sechszylinder   hilow, I'm using fpga's since 10 years an...   Nov 11 2003, 02:52 AM
jkeyzer   Andy - Did you ever code on the Amiga? I did not k...   Nov 11 2003, 10:22 AM
SirAndy   <...   Nov 11 2003, 12:48 PM
- Lo-Fi Version Time is now: 14th September 2026 - 11:04 PM
