| need4speed |
Nov 10 2003, 02:22 PM
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
I'm still a drooler, but I may have my first 914 in a couple of weeks if things work out.
And I'm already dreaming of building my own FI system (though the car I'm looking at is a 1.8 with what the owner says is a good, working L-Jet system). And I'm wondering - has anybody ever seen an FI brain that uses an FPGA chip, instead of a regular chip designed for the task? A buddy of mine works at Xylinx, and he explained to me about these FPGA chips - mostly used in routers and stuff - it's basically a big array of programmable gates, and you can load a program on by physically configuring the gates a certain way, and then, instead of loading software in to run on the chip - the chip works as if it's a custom designed IC. I kind of thought I'd like to try using something like this - I'm not a really experienced programmer, but I have worked with computers for 12 years, and I've always wanted to take on a project like this. Any thoughts? |
| SirAndy |
Nov 10 2003, 02:59 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,517 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(fiid @ Nov 10 2003, 12:38 PM) The Megasquirt is based on a variant of the 68000 that has embedded eeprom and some ram. yepp. a cheap-o 8-Bit 68000 clone. no FPU either. makes for fun floating point operations ... good thing i used to do OS programming in assembler way before anyone even thought about a FPU (IMG:style_emoticons/default/cool.gif) Andy |
need4speed FI programming geek question Nov 10 2003, 02:22 PM
fiid Most of everything built these days has a full-on ... Nov 10 2003, 02:38 PM
Mueller it sounds like a PLC but much smaller than the nor... Nov 10 2003, 02:41 PM
fiid FPUs are for wusses. :-)
You're right the CPU... Nov 10 2003, 03:58 PM
sechszylinder hilow,
I'm using fpga's since 10 years an... Nov 11 2003, 02:52 AM
jkeyzer Andy - Did you ever code on the Amiga?
I did not k... Nov 11 2003, 10:22 AM
SirAndy <... Nov 11 2003, 12:48 PM
SirAndy ![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 11:04 PM |
