Where the pan meets the longitudinal..., ...waddaya think? |
1970 Neun vierzehn |
Dec 9 2006, 01:11 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Now I'm getting uneasy....the shop sez the longs are fine, I'm getting feedback from folks whose opinion I value that they're bad. Obviously the pan is rotted, but where does the one end , and the other start? I colored the long "orange" to highlight it from the rusted pan.
Attached image(s) |
SirAndy |
Dec 9 2006, 02:10 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
everything *between* the yellow lines is the bottom of your long !!!!
everything inside the red lines shows the bottom of the hell hole ... everything inside the green lines is your floorpan ... like i said before, that round tube you see is the metal part of the heater tube that runs inside the long (IMG:style_emoticons/default/ohmy.gif) if the longs were OK, you shouldn't be able to see inside ... makes sense? (IMG:style_emoticons/default/cool_shades.gif) Andy PS: this *is* fixable, but it's not an easy repair. you will HAVE TO support the chassis correctly to keep it within specs before you weld this up. your chassis is already flexing and out of spec as it is. the two longs are the spine that holds your car together. if one is weakend like that, your car *is* flexing ... Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:36 PM |
