Can this sail panel be fixed?, ...and what can be done to prevent later |
boxsterfan |
Nov 11 2003, 10:02 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
For those who have leaking rear windows (that would be all of you), this might be a bit gruesome. (IMG:style_emoticons/default/sad.gif)
Can this sail panel be fixed without cutting it out and replacing with a whole new (to me) one? Drivers Sail Panel \"Head-On\" Drivers Sail Panel \"Side View\" Drivers Sail Panel \"Side View 2\" This car is planned to be acid dipped. If this can be fixed with fiberglass or other material, what can be done to help protect the inside of the sail panel? I stuck a flashlight up to it, and of course. there is surface rust all over inside the panel. Is there a "foam" that could be squirted in there? Or squirt as much POR-15 as possible in there and then fill with a water resistant foam? Or....? |
Andyrew |
Nov 11 2003, 10:31 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
From what I have heard, foam is bad, the foam may be water resistant, but the metal isnt... I would cut it open so you could clean the area better, and then por 15 the area.. Dont know..
Andrew |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:02 PM |
