Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
OK, I finaly did it. I purchased a 3.0L and I am going to put it in my 6! (IMG:style_emoticons/default/burnout.gif)
So here is what I need: Any photos, data, tips, directions, information and help in stuffing this thing in!! I am planning on crank fire ign. and leaving the injection. I am using the 901 stock transmission currently in my 6. Jeff PS: I will post photos as I progress. |
Jeffs9146 |
QUOTE Can't use the 2L /6 flywheel. <=2.7L used different # of flywheel bolts on the crank compared to >=3L motors. The ~76 Carrera3.0 still used the old 6(?) bolt crank, but I think its the only one that didn't fit the rule. OK, so do I modify the 3.0 flywheel or what do I purchase? QUOTE You want to use crank trigger, but retain CIS? Thats an odd one. If you retain CIS, mught as well leave the dizzy alone. It will be FAR simpler and no diff in power. I was told that I could add crank fire and eliminate the timing problem, a hard to get too dizzy. I have Webers but I would prefer to keep the CIS. If I can't add crank fire then I will just leave everything stock 3.0. Jeff |
Lo-Fi Version | Time is now: 1st August 2025 - 10:01 AM |
