> OK, I did it! 3.0l 6 ready to make it happen, Any tips are welcome.
Jeffs9146
post Dec 12 2006, 04:51 PM
Ski Bum
OK, I finaly did it. I purchased a 3.0L and I am going to put it in my 6! (IMG:style_emoticons/default/burnout.gif)
So here is what I need:
Any photos, data, tips, directions, information and help in stuffing this thing in!!
I am planning on crank fire ign. and leaving the injection. I am using the 901 stock transmission currently in my 6.
Jeff
PS: I will post photos as I progress.
Jeffs9146
post Dec 28 2006, 10:52 PM
Ski Bum
Can I use the 2.0L oil cooler and avoid the cutting and welding?
Jeff
ClayPerrine
post Dec 29 2006, 06:32 AM
QUOTE(Jeffs9146 @ Dec 28 2006, 10:52 PM) *
Jeff
No.. the 2.0L 911 cooler comes straight out the end, and will hit the trailing arm.
You need to alter it, and it is smaller than the 3.0 cooler that is on your engine.
Jeffs9146   OK, I did it! 3.0l 6 ready to make it happen   Dec 12 2006, 04:51 PM
markb   Begin drinking heavily now. That way it's not ...   Dec 12 2006, 05:15 PM
pete-stevers   Whoo Hoo..another 3.0.....if you need any specific...   Dec 12 2006, 05:26 PM
Jeffs9146   Thanks Pete! I would like to hear how you did...   Dec 12 2006, 06:11 PM
JOHNMAN
  Dec 12 2006, 09:49 PM
Scott Carlberg   Huh? I thought that last 914 you bought WAS a 6, ...   Dec 13 2006, 01:12 AM
Jeffs9146   Hey Scott, Yes it is currently a 6 and I am dropp...   Dec 26 2006, 03:00 PM
John   Hey Scott, Yes it is currently a 6 and I am drop...   Dec 26 2006, 03:07 PM
smdubovsky   You want to use crank trigger, but retain CIS? Th...   Dec 26 2006, 03:18 PM
Jeffs9146   OK, so do I modify the 3.0 flywheel or what do I...   Dec 26 2006, 03:35 PM
echocanyons   What year is your 3.0 from? later 81-83 have the ...   Dec 26 2006, 04:14 PM
seanery   :GreenWithEnvy: congrats!! :woohoo:   Dec 26 2006, 05:05 PM
GeorgeRud   I've done a similar conversion using the Crank...   Dec 26 2006, 08:37 PM
brp914   no points on a 3L dizzy If keeping the cis, I sec...   Dec 27 2006, 12:07 AM
Jeffs9146   I was told it was an 83 and it came with the fuel ...   Dec 27 2006, 12:42 PM
echocanyons   If you have an 83 than chances are you have the la...   Dec 27 2006, 01:29 PM
echocanyons   Isn't the acculmulator for hot starts? You m...   Dec 27 2006, 01:33 PM
Jeffs9146   The motor is a *64D2000*+ which is what I was told...   Dec 27 2006, 02:54 PM
shadygrady   I have a 3.0L from an 83 SC. I kept the stock CIS...   Dec 27 2006, 05:20 PM
Jeffs9146   Yes, I spoke with Kennedy this afternoon and the...   Dec 27 2006, 06:38 PM
brp914   with cis you may need to time off the front pull...   Dec 27 2006, 09:59 PM
Jeffs9146   Thanks for the info, keep it comming! Did y...   Dec 27 2006, 10:07 PM
brp914   yep, accumulater installed. I think you'll ne...   Dec 27 2006, 11:30 PM
Jeffs9146   OK, so I need to remove the oil cooler? I was to...   Dec 28 2006, 12:07 AM
Lou W   Ok, I'll be the first to say; :ttiwwp:   Dec 28 2006, 09:37 AM
ClayPerrine   Another solution to the clutch is to use a 70-71 p...   Dec 28 2006, 09:45 AM
Jeffs9146   Thats the kind of stuff I need to know! Than...   Dec 28 2006, 10:54 AM
brp914   one way is like so...   Dec 28 2006, 09:54 PM
Jeffs9146   Can I use the 2.0L oil cooler and avoid the cuttin...   Dec 28 2006, 10:52 PM
ClayPerrine   Can I use the 2.0L oil cooler and avoid the cutti...   Dec 29 2006, 06:32 AM
brp914   I wondered about that too, but I don't know.   Dec 28 2006, 11:17 PM
Jeffs9146   I have a 2.0 914-6 cooler. That will work wont it?...   Dec 29 2006, 11:25 AM
echocanyons   Yep the 2.0 cooler is smaller and may not provide ...   Dec 29 2006, 12:01 PM
Jeffs9146   I was planning on photographing every step. I am s...   Dec 29 2006, 01:07 PM
echocanyons   http://www.gprparts.com/ is his web site. It is b...   Dec 29 2006, 01:47 PM
echocanyons   here is a picture of the 911 setup, you can see th...   Dec 29 2006, 01:53 PM
echocanyons   http://www.pelicanparts.com/cgi-bin/smart/imgdsply...   Dec 29 2006, 01:54 PM
iamchappy   Clewett does the oil cooler mod. for 145.00 http:/...   Dec 29 2006, 02:08 PM
Jeffs9146   Thanks, that seems reasonable! Jeff   Dec 29 2006, 03:17 PM
- Lo-Fi Version Time is now: 1st August 2025 - 10:02 AM
