> OK, I did it! 3.0l 6 ready to make it happen, Any tips are welcome.
Jeffs9146
post Dec 12 2006, 04:51 PM
Ski Bum
OK, I finaly did it. I purchased a 3.0L and I am going to put it in my 6! (IMG:style_emoticons/default/burnout.gif)
So here is what I need:
Any photos, data, tips, directions, information and help in stuffing this thing in!!
I am planning on crank fire ign. and leaving the injection. I am using the 901 stock transmission currently in my 6.
Jeff
PS: I will post photos as I progress.
iamchappy
post Dec 29 2006, 02:08 PM
It all happens so fast!
Clewett does the oil cooler mod. for 145.00
http://www.clewett.com/
Jeffs9146   OK, I did it! 3.0l 6 ready to make it happen   Dec 12 2006, 04:51 PM
markb   Begin drinking heavily now. That way it's not ...   Dec 12 2006, 05:15 PM
pete-stevers   Whoo Hoo..another 3.0.....if you need any specific...   Dec 12 2006, 05:26 PM
Jeffs9146   Thanks Pete! I would like to hear how you did...   Dec 12 2006, 06:11 PM
JOHNMAN
  Dec 12 2006, 09:49 PM
Scott Carlberg   Huh? I thought that last 914 you bought WAS a 6, ...   Dec 13 2006, 01:12 AM
Jeffs9146   Hey Scott, Yes it is currently a 6 and I am dropp...   Dec 26 2006, 03:00 PM
John   Hey Scott, Yes it is currently a 6 and I am drop...   Dec 26 2006, 03:07 PM
smdubovsky   You want to use crank trigger, but retain CIS? Th...   Dec 26 2006, 03:18 PM
Jeffs9146   OK, so do I modify the 3.0 flywheel or what do I...   Dec 26 2006, 03:35 PM
echocanyons   What year is your 3.0 from? later 81-83 have the ...   Dec 26 2006, 04:14 PM
seanery   :GreenWithEnvy: congrats!! :woohoo:   Dec 26 2006, 05:05 PM
GeorgeRud   I've done a similar conversion using the Crank...   Dec 26 2006, 08:37 PM
brp914   no points on a 3L dizzy If keeping the cis, I sec...   Dec 27 2006, 12:07 AM
Jeffs9146   I was told it was an 83 and it came with the fuel ...   Dec 27 2006, 12:42 PM
echocanyons   If you have an 83 than chances are you have the la...   Dec 27 2006, 01:29 PM
echocanyons   Isn't the acculmulator for hot starts? You m...   Dec 27 2006, 01:33 PM
Jeffs9146   The motor is a *64D2000*+ which is what I was told...   Dec 27 2006, 02:54 PM
shadygrady   I have a 3.0L from an 83 SC. I kept the stock CIS...   Dec 27 2006, 05:20 PM
Jeffs9146   Yes, I spoke with Kennedy this afternoon and the...   Dec 27 2006, 06:38 PM
brp914   with cis you may need to time off the front pull...   Dec 27 2006, 09:59 PM
Jeffs9146   Thanks for the info, keep it comming! Did y...   Dec 27 2006, 10:07 PM
brp914   yep, accumulater installed. I think you'll ne...   Dec 27 2006, 11:30 PM
Jeffs9146   OK, so I need to remove the oil cooler? I was to...   Dec 28 2006, 12:07 AM
Lou W   Ok, I'll be the first to say; :ttiwwp:   Dec 28 2006, 09:37 AM
ClayPerrine   Another solution to the clutch is to use a 70-71 p...   Dec 28 2006, 09:45 AM
Jeffs9146   Thats the kind of stuff I need to know! Than...   Dec 28 2006, 10:54 AM
brp914   one way is like so...   Dec 28 2006, 09:54 PM
Jeffs9146   Can I use the 2.0L oil cooler and avoid the cuttin...   Dec 28 2006, 10:52 PM
ClayPerrine   Can I use the 2.0L oil cooler and avoid the cutti...   Dec 29 2006, 06:32 AM
brp914   I wondered about that too, but I don't know.   Dec 28 2006, 11:17 PM
Jeffs9146   I have a 2.0 914-6 cooler. That will work wont it?...   Dec 29 2006, 11:25 AM
echocanyons   Yep the 2.0 cooler is smaller and may not provide ...   Dec 29 2006, 12:01 PM
Jeffs9146   I was planning on photographing every step. I am s...   Dec 29 2006, 01:07 PM
echocanyons   http://www.gprparts.com/ is his web site. It is b...   Dec 29 2006, 01:47 PM
echocanyons   here is a picture of the 911 setup, you can see th...   Dec 29 2006, 01:53 PM
echocanyons   http://www.pelicanparts.com/cgi-bin/smart/imgdsply...   Dec 29 2006, 01:54 PM
iamchappy   Clewett does the oil cooler mod. for 145.00 http:/...   Dec 29 2006, 02:08 PM
Jeffs9146   Thanks, that seems reasonable! Jeff   Dec 29 2006, 03:17 PM
- Lo-Fi Version Time is now: 1st August 2025 - 10:03 AM
