Removal of Targa Trim, How does one remove? |
boxsterfan |
Nov 11 2003, 06:26 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
OK, I seem to be turning and turning the screwdriver, but am unable to get the targa trim to come loose.
So what is the trick? Trying not to damage anything even though this piece is severely cracked all over. The piece I am trying to get loose is in this image (hope it attaches). Attached image(s) |
3d914 |
Nov 12 2003, 01:19 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
boxterfan,
If I remember correctly, there are like a dozen screws that hold that piece in. You must also remove the rear targa latches. The screws may just turn because once they're loose the foam inside the trim holds them in place. If you loosen all the screws, remove the pieces mentioned previously, you should be able to slide it forward & off. Good luck, |
Lo-Fi Version | Time is now: 17th June 2024 - 12:13 AM |
