| xperu |
Jan 2 2007, 06:24 AM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
I have a 1974 FI 1.7, my problem is the relay continues to foul with corrosion. I clean it with electrical contact cleaner, but the problem which clears the corrosion problem for a short time. The car runs flawless except this problem and I really can't rely on the car any longer. I there a way to bypass the relay directly to the fuel pump? Thanks Mike
| BMartin914 |
Jan 2 2007, 08:41 AM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I have a 1974 FI 1.7, my problem is the relay continues to foul with corrosion. I clean it with electrical contact cleaner, but the problem which clears the corrosion problem for a short time. The car runs flawless except this problem and I really can't rely on the car any longer. I there a way to bypass the relay directly to the fuel pump? Thanks Mike Have you used dielectric grease after cleaning? It should prevent any corrosion from occuring. |
xperu Power from relay to fuel pump Jan 2 2007, 06:24 AM
rmital
I have a 1974 FI 1.7, my problem is the relay con... Jan 2 2007, 08:09 AM
SLITS And instead of cleaner in a can .... try a wire br... Jan 2 2007, 06:41 PM
SGB There is more resistance somewhere...
try pulling ... Jan 2 2007, 09:06 PM
xperu
try pulling... Jan 3 2007, 06:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 05:41 PM |
