BenNC |
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 ![]() |
I know that it has been posted before, but I can't find it.
What are typical cylinder head temperatures when measured using an under the plug type of sender? Thanks, |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
If you are lean, the engine may hunt at idle (FI? Carbs?) also, you would notice your head temps above normal..
Too much advance. I run a gear lower than you do at the same speed... I am betting you are over-advanced, if you leave it in 4th, what's the temps? Cooler? -edit Ben, have you checked that all of your fins, and the fan, and the tin aren't fouled by leaves or pooh of any kind? M |
Lo-Fi Version | Time is now: 8th July 2025 - 09:32 PM |
