Wheel frozen to the hub |
GaroldShaffer |
Nov 12 2003, 10:36 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Thought I would start on the front of the parts car. Driver
side tire came off no problem, passenger side just hangs there. I can't get it off and yes the lug bolts are out and the tire is off the ground. This is the 74 LE that has sat for 18yrs. Any thoughts? - Garold |
Engman |
Nov 13 2003, 02:47 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Maybe you should fix it up to get it running to loosen the wheel. Then you can junk it. (IMG:style_emoticons/default/lol3.gif)
Mine had the same problem - take your time go around the rim and by all means protect the rims from being hit with the sledge. You might try to get some penetrating oil in on the hub area. (IMG:style_emoticons/default/smash.gif) Have patience - it will come off. M |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:16 PM |
