| Hammy |
Jan 13 2007, 02:46 AM
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California |
So I received my Dakota Digital CHT gauge today (IMG:style_emoticons/default/mueba.gif) Looks great
Anyways, I have some questions and I want some answers (IMG:style_emoticons/default/cool_shades.gif) 1 - The gauge sender washer/loop/ring end is just a hair too small to slide/thread onto the spark plug. I did order the correct size, 14mm, but it seems still just a tad too small. Is it ok to open the hole up just a little tiny bit more? It seems highly doubtful it'd be a problem, but just checking. 2 - Does the sender ring replace the spark plug washer? If not, does it go in front of the washer, or in between the washer and plug? 3 - The gauge has a night dimming feature so that when the headlights are turned on, it dims the output of the gauge (it's a digital display). I notice there are some unhooked male spade connectors in the center tunnel wiring harness, behind the shifter. They have a plastic protector box around them. What are they for? I think I've read that they're for center console gauge lights, correct? Thanks for any help |
Dave_Darling #3 -- The wires are for all of the center console ... Jan 13 2007, 12:24 PM
Aaron Cox bump for hammy to get some answers on CHT Jan 16 2007, 01:24 PM
McMark 1- Yep, I've seen people grind them. I can... Jan 16 2007, 01:27 PM
Rand File the inside with a round file just enough so y... Jan 16 2007, 01:29 PM
SLITS Just thread the ring on like you were screwing the... Jan 16 2007, 01:55 PM
Hammy Thanks AA for the bump
I tried to thread it ont... Jan 16 2007, 05:02 PM
spunone Hammy which gauge did you buy and how long where t... Jan 16 2007, 05:18 PM
Hammy
Hammy which gauge did you buy and how long where ... Jan 16 2007, 05:29 PM
spunone Wonder if you can put on a switch and use another ... Jan 16 2007, 06:22 PM
Rand
Wonder if you can put on a switch and use another... Jan 16 2007, 06:24 PM
Hammy
Wonder if you can put on a switch and use anothe... Jan 16 2007, 09:27 PM
spunone Talked to the fellas at Dakota Dig nope can't... Jan 30 2007, 02:40 PM
Hammy
Talked to the fellas at Dakota Dig nope can... Jan 30 2007, 04:31 PM
spunone They say you can cut it just can't add to it a... Jan 30 2007, 04:34 PM
Rand My info said not to cut it at all... Don't sho... Jan 30 2007, 05:05 PM
Aaron Cox resistance changes with wire length right? so if t... Jan 30 2007, 05:33 PM
spunone Ok so why did 1 sales scum then a tech guy say you... Jan 30 2007, 05:57 PM
spunone Oh yeah I think they made the sender for a vw bus Jan 30 2007, 05:58 PM
Mark Garriott If you get the 12mm sender, you get a choice betwe... Jan 30 2007, 06:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:37 PM |
