Project Turbo 914 begins..., (yes, I know you can't turbo a 914) |
ottox914 |
Dec 24 2006, 01:44 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just a little teaser on this winters project. Last winter I dug into this little update:
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= This winter will be phase 2. This photo will show some of the goodies under the tree, which will soon be under/on the car. The WRX intercooler has one round inlet on the back, and 2 smaller oval outlets under the opposite end tank. These will each exit and attach to some CB performance turbo "hats" for the ITB's that have 2" tubes welded to them. Some silicone elbows, and we're good. The intercooler will mount on braces running across the engine bay to support the intercooler as close to the GT lid as possible. I'll see how it goes, and probably do some yarn tuft testing to see about airflow in and around that lid, but I could always use the SDS computer to switch on either a puller or pusher fan below the intercooler based on boost, if needed. The turbo will mount on a custom flange/adaptor to be built to connect the turbo to the collector of the Kerry Hunter exhaust system. The turbo is a small Garrett VNT. The compressor map looks like a good match for this motor. I'm expecting the VNT turbo to give good low rpm thorttle response. Starting out at 5-6 psi, I'd be happy to see 10 when I'm done, but will tune to run safely on 93 pump gas and see where we end up. Off the back of the transmission, where the factory exhaust hanger mounted, I'll mount a similar hanger to support the turbo and exhaust system. A Tildon differential pump will return the oil to a willing valve cover. Oil will be taken from a "T" at the pressure sending unit on the case. There is a blow off valve to be added to the intercooler, and a mocal thermostat/sandwitch plate adaptor for the oil cooler, which has a thermostat controlled fan. I'll be adding an ignition switched relay for power to the fan and scavenge pump, so both will have power when the key is on. The pump will run continously, the fan when the thermo switch tells it to. Add some pressure side stainless or aluminum tubing from the turbo, thru the back engine tin, into the round inlet on the intercooler and we're done. Except for another trip to the LSE dyno, for some additional tuning. I'll keep posting as progress would warrent. Attached image(s) |
ottox914 |
Jan 13 2007, 08:36 PM
1-16-07 updates- got the oil cooler installed- sort of. I'll be taking it out to add the fittings and connect the hoses, but here's how it went:
first photo is a hard to cut up trunk, but then again, I put holes in it for the rear sway bar, so whats the deal with 4 more? second photo is 4 perfectly sized holes, courtesy of photo three, the unibit! *I went back and forth from under the car to in the trunk at least a half a dozen times to decide where to drill. I then laid the cooler out in the trunk, marked for holes, drilled 2 sizes of pilot hole, then had at it with the unibit. In retrospect, I should have moved things to the outside of the car 1/2 an inch or so, the "bumps" in the trunk carpet would have been less if I had put all the nuts in the low spots of the trunk. Oh well, whats done is done, and with the rubber insulation mat and carpet in, you don't really notice the bumps that much. photo 4 is the cooler, wired up. you need to attach a wire from the thermostat to the fan motor, attach the other wire to the thermostat to a (+) with 15 amp fuse, and attach the other wire from the fan motor to ground. The ground will be going back by the transmission, and attaching at the braded ground strap. the (+) will be going to the back of the verticle engine tin, where I will be installing a relay to power the fan and scavenge pump. I'll be moving my "hot start" relay to that location as well, so there will be 2 side by side. Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 03:59 AM |
