Project Turbo 914 begins..., (yes, I know you can't turbo a 914) |
ottox914 |
Dec 24 2006, 01:44 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just a little teaser on this winters project. Last winter I dug into this little update:
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= This winter will be phase 2. This photo will show some of the goodies under the tree, which will soon be under/on the car. The WRX intercooler has one round inlet on the back, and 2 smaller oval outlets under the opposite end tank. These will each exit and attach to some CB performance turbo "hats" for the ITB's that have 2" tubes welded to them. Some silicone elbows, and we're good. The intercooler will mount on braces running across the engine bay to support the intercooler as close to the GT lid as possible. I'll see how it goes, and probably do some yarn tuft testing to see about airflow in and around that lid, but I could always use the SDS computer to switch on either a puller or pusher fan below the intercooler based on boost, if needed. The turbo will mount on a custom flange/adaptor to be built to connect the turbo to the collector of the Kerry Hunter exhaust system. The turbo is a small Garrett VNT. The compressor map looks like a good match for this motor. I'm expecting the VNT turbo to give good low rpm thorttle response. Starting out at 5-6 psi, I'd be happy to see 10 when I'm done, but will tune to run safely on 93 pump gas and see where we end up. Off the back of the transmission, where the factory exhaust hanger mounted, I'll mount a similar hanger to support the turbo and exhaust system. A Tildon differential pump will return the oil to a willing valve cover. Oil will be taken from a "T" at the pressure sending unit on the case. There is a blow off valve to be added to the intercooler, and a mocal thermostat/sandwitch plate adaptor for the oil cooler, which has a thermostat controlled fan. I'll be adding an ignition switched relay for power to the fan and scavenge pump, so both will have power when the key is on. The pump will run continously, the fan when the thermo switch tells it to. Add some pressure side stainless or aluminum tubing from the turbo, thru the back engine tin, into the round inlet on the intercooler and we're done. Except for another trip to the LSE dyno, for some additional tuning. I'll keep posting as progress would warrent. Attached image(s) |
ottox914 |
Jan 15 2007, 09:24 PM
Lee and Dave-o came over for the day. We played some guitar, messed with the yellow car, made some good progress. Did some electrical upgrades, re-did the oil cooler, its much better now, got it connected, test fired, no leaks, tore out the back pad, and got the intercooler mounts made. Forgot to bring a camera. Will try to get back to the shop tuesday afternoon for some snapshots, and will post more then.
The to-do list remains long. I need to get the boost gauge mounted, wired, plumbed. Need to get vacuume lines run to the RR fuel pressure regulator, blow off valve, and turbo. Need to move the cold start solinoid, and add another one to power the scavenge pump and the oil cooler fan. Need to make some intercooler piping. Need to run oil lines to the turbo, mount the scavenge pump, pressure switch, and return line. Then get it off to LSE for fabrication of the intercooler to the ITB hat lines, and the turbo mount. Then figure out how to post a movie to this site... |
Lo-Fi Version | Time is now: 11th June 2024 - 09:14 AM |
