> couple quick CHT gauge questions, sender and gauge lighting
Hammy
post Jan 13 2007, 02:46 AM
mr. Wonderful
So I received my Dakota Digital CHT gauge today (IMG:style_emoticons/default/mueba.gif) Looks great
Anyways, I have some questions and I want some answers (IMG:style_emoticons/default/cool_shades.gif)
1 - The gauge sender washer/loop/ring end is just a hair too small to slide/thread onto the spark plug. I did order the correct size, 14mm, but it seems still just a tad too small. Is it ok to open the hole up just a little tiny bit more? It seems highly doubtful it'd be a problem, but just checking.
2 - Does the sender ring replace the spark plug washer? If not, does it go in front of the washer, or in between the washer and plug?
3 - The gauge has a night dimming feature so that when the headlights are turned on, it dims the output of the gauge (it's a digital display). I notice there are some unhooked male spade connectors in the center tunnel wiring harness, behind the shifter. They have a plastic protector box around them. What are they for? I think I've read that they're for center console gauge lights, correct?
Thanks for any help
spunone
post Jan 16 2007, 05:18 PM
Hammy which gauge did you buy and how long where the wires did you dash mount or in the center consule
Hammy   couple quick CHT gauge questions   Jan 13 2007, 02:46 AM
Dave_Darling   #3 -- The wires are for all of the center console ...   Jan 13 2007, 12:24 PM
Aaron Cox   bump for hammy to get some answers on CHT   Jan 16 2007, 01:24 PM
McMark   1- Yep, I've seen people grind them. I can...   Jan 16 2007, 01:27 PM
Rand   File the inside with a round file just enough so y...   Jan 16 2007, 01:29 PM
SLITS   Just thread the ring on like you were screwing the...   Jan 16 2007, 01:55 PM
Hammy   Thanks AA for the bump I tried to thread it ont...   Jan 16 2007, 05:02 PM
spunone   Hammy which gauge did you buy and how long where t...   Jan 16 2007, 05:18 PM
Hammy   Hammy which gauge did you buy and how long where ...   Jan 16 2007, 05:29 PM
spunone   Wonder if you can put on a switch and use another ...   Jan 16 2007, 06:22 PM
Rand   Wonder if you can put on a switch and use another...   Jan 16 2007, 06:24 PM
Hammy   Wonder if you can put on a switch and use anothe...   Jan 16 2007, 09:27 PM
spunone   Talked to the fellas at Dakota Dig nope can't...   Jan 30 2007, 02:40 PM
Hammy   Talked to the fellas at Dakota Dig nope can...   Jan 30 2007, 04:31 PM
spunone   They say you can cut it just can't add to it a...   Jan 30 2007, 04:34 PM
Rand   My info said not to cut it at all... Don't sho...   Jan 30 2007, 05:05 PM
Aaron Cox   resistance changes with wire length right? so if t...   Jan 30 2007, 05:33 PM
spunone   Ok so why did 1 sales scum then a tech guy say you...   Jan 30 2007, 05:57 PM
spunone   Oh yeah I think they made the sender for a vw bus   Jan 30 2007, 05:58 PM
Mark Garriott   If you get the 12mm sender, you get a choice betwe...   Jan 30 2007, 06:56 PM
- Lo-Fi Version Time is now: 16th April 2026 - 08:34 PM
