Wednesday, 13 August 2025
> Have you seen a 915 tranny swap thread?, With pictures would be great.
Twystd1
post Jan 24 2007, 12:44 AM
You don't want to know... really.....
OK,
I screwed up on another board and gave very incomplete data to someone.
I can't find a 915 swap thread using the search function.
I am looking for a thread that explains ALL of the issues with this conversion.
If you guys know of any thread on any board.
Please let me know. I really want to help this guy get it right.
Thanks fellas,
Clayton
post Jan 24 2007, 10:15 AM
I'm doing some work on my 915 conversion right now, have it out of the car and apart, so I've become very familiar with it. What issue are you looking at? There are quite a few. None are a huge deal, but they do kinda add up.
You have to have a way to mount it and to shift it. There's the Vellios kit and the Wevo kit to do that. It can be linkage shifted, you need to have a customized shift bar to do that (the angles have to be right). Or it can be cable shifted, but I wouldn't personally do that, at least based on the discontent I've heard from a lot of cable shift setups. With a stock style linkage/bar setup, my 915 in my 914 shifts just like my 915 in my 911.
You need a custom/modified pulley system for the clutch cable. You have to flip the RP. You have to adapt axles, but there's a lot of ways to do that. My 915 is from a '78 and is electronic speedo, I'm not 100% sure about the earlier ones, but I think they are all electric, so in a 914, you need a new speedo. Since it's driven off the RP, you also need to machine something in the case to relocate the speedo sensor.
From what I can see, that's it.
The 915 is a very good transmission, capable of holding a good amount of power. The only semi-weakness is 2nd gear, and 2nd gears only weakness is when you powershift into it (shift quickly then apply full power very quickly) with a lot of HP (say high 200s to 300+). If you just take it a bit easy on the shifts into second, it lasts a long time. The only real upgrade you can do to it for a 914 application is the Wevo bearing retainer, which harnesses the input and pinion bearing shafts together.
Twystd1   Have you seen a 915 tranny swap thread?   Jan 24 2007, 12:44 AM
Twystd1   McFly? C   Jan 24 2007, 02:18 AM
Twystd1   Z... You ever done this?????????????   Jan 24 2007, 09:57 AM
mikez   Z... You ever done this????????????? Nope...I ...   Jan 24 2007, 12:35 PM
914-8   I'm doing some work on my 915 conversion right...   Jan 24 2007, 10:15 AM
Twystd1   Thanks for the info.. That is great data.......   Jan 24 2007, 10:28 AM
Hoss   ... I hope more data will be coming forward to he...   Jan 24 2007, 10:50 AM
Twystd1   will do...!!!!! Keep it comin...   Jan 24 2007, 10:56 AM
Crazyhippy   Nicely stolen from Renegade Hybrids webpage BJH   Jan 24 2007, 11:57 AM
Twystd1   Thats very interesting Mike. Care to give us a li...   Jan 24 2007, 01:17 PM
mikez   Thats very interesting Mike. Care to give us a l...   Jan 24 2007, 02:12 PM
Twystd1   {EDIT} It's Aarons fault I double posted.... ...   Jan 24 2007, 01:18 PM
914-8   As far as transmission choices, I think it depends...   Jan 24 2007, 01:28 PM
dr914@autoatlanta.com   Having both a 914 issued from the FACTORY with a 9...   Jan 24 2007, 01:37 PM
bondo   What's it take to put a G50 in a 914? Doesn...   Jan 24 2007, 02:19 PM
Crazyhippy   G-50 factory ratios are ok... not perfect, but not...   Jan 24 2007, 04:00 PM
bondo   G-50 factory ratios are ok... not perfect, but no...   Jan 24 2007, 04:13 PM
Crazyhippy   G-50 factory ratios are ok... not perfect, but n...   Jan 24 2007, 04:33 PM
Aaron Cox   talk to mugs 914.... he put a g50 in his race car...   Jan 24 2007, 04:27 PM
GeorgeRud   There's a fellow (Derick) that has a 904 recre...   Jan 24 2007, 04:47 PM
Twystd1   Man... This might turn out to be a sticky... This...   Jan 24 2007, 04:49 PM
Aaron Cox   Man... This might turn out to be a sticky... Thi...   Jan 24 2007, 05:23 PM
Twystd1   I am SSooooo gunna hit you on the side of your hea...   Jan 24 2007, 05:58 PM
LarryR   I am kind of suprised at the lumping of all 915...   Mar 18 2007, 04:34 PM
- Lo-Fi Version Time is now: 13th August 2025 - 04:40 AM
