> Have you seen a 915 tranny swap thread?, With pictures would be great.
Twystd1
post Jan 24 2007, 12:44 AM
You don't want to know... really.....
OK,
I screwed up on another board and gave very incomplete data to someone.
I can't find a 915 swap thread using the search function.
I am looking for a thread that explains ALL of the issues with this conversion.
If you guys know of any thread on any board.
Please let me know. I really want to help this guy get it right.
Thanks fellas,
Clayton
GeorgeRud
post Jan 24 2007, 04:47 PM
There's a fellow (Derick) that has a 904 recreation he's working on (P904@shaw.ca). He has a 930 box with the Vellios conversion for sale for $8500, a good price in my opinion considering the steps you have to go through.
Dr. 914s comments on the 915 conversion seem quite right on. I used the Vellios conversion on mine, and had similar experiences. The 915 does shift nicely now, but I used a 915 shift tower, custom made linkage from metric sized metal tubing, and a nicely converted transmission. All the items can be taken care of pretty easily, and even the clutch cable works OK. I used the 90 degree adapter from Patrick to change the orientation of the pulley to horizontal.
A billet side plate with a mount for the electronic speedo sendor would be a nice part, but I used the standard one with a machined area between two stiffening ribs to mount the sender.
The Vellios tailpiece seems to take care of the spacing, as my transmission fit without any clearance issues. I also used the WEVO transmission mounts to help the shifting, and a Rich Johnson front mount.
I used an early (1975) 915 transmission, so I had the course splined output shafts already. I simply had to swap them for the 914 ones, and the axles were taken care of. I have been slowly assembling the necessary parts to go back to the larger CV jointed axles, but that's for a future project.
Another minor point is that you have to come up with some way of switching the backup lights as the 915 doesn't have the required boss on the side. I mounted a microswitch to the transmission, and an activating lever on the shift rod itself.
Twystd1   Have you seen a 915 tranny swap thread?   Jan 24 2007, 12:44 AM
Twystd1   McFly? C   Jan 24 2007, 02:18 AM
Twystd1   Z... You ever done this?????????????   Jan 24 2007, 09:57 AM
mikez   Z... You ever done this????????????? Nope...I ...   Jan 24 2007, 12:35 PM
914-8   I'm doing some work on my 915 conversion right...   Jan 24 2007, 10:15 AM
Twystd1   Thanks for the info.. That is great data.......   Jan 24 2007, 10:28 AM
Hoss   ... I hope more data will be coming forward to he...   Jan 24 2007, 10:50 AM
Twystd1   will do...!!!!! Keep it comin...   Jan 24 2007, 10:56 AM
Crazyhippy   Nicely stolen from Renegade Hybrids webpage BJH   Jan 24 2007, 11:57 AM
Twystd1   Thats very interesting Mike. Care to give us a li...   Jan 24 2007, 01:17 PM
mikez   Thats very interesting Mike. Care to give us a l...   Jan 24 2007, 02:12 PM
Twystd1   {EDIT} It's Aarons fault I double posted.... ...   Jan 24 2007, 01:18 PM
914-8   As far as transmission choices, I think it depends...   Jan 24 2007, 01:28 PM
dr914@autoatlanta.com   Having both a 914 issued from the FACTORY with a 9...   Jan 24 2007, 01:37 PM
bondo   What's it take to put a G50 in a 914? Doesn...   Jan 24 2007, 02:19 PM
Crazyhippy   G-50 factory ratios are ok... not perfect, but not...   Jan 24 2007, 04:00 PM
bondo   G-50 factory ratios are ok... not perfect, but no...   Jan 24 2007, 04:13 PM
Crazyhippy   G-50 factory ratios are ok... not perfect, but n...   Jan 24 2007, 04:33 PM
Aaron Cox   talk to mugs 914.... he put a g50 in his race car...   Jan 24 2007, 04:27 PM
GeorgeRud   There's a fellow (Derick) that has a 904 recre...   Jan 24 2007, 04:47 PM
Twystd1   Man... This might turn out to be a sticky... This...   Jan 24 2007, 04:49 PM
Aaron Cox   Man... This might turn out to be a sticky... Thi...   Jan 24 2007, 05:23 PM
Twystd1   I am SSooooo gunna hit you on the side of your hea...   Jan 24 2007, 05:58 PM
LarryR   I am kind of suprised at the lumping of all 915...   Mar 18 2007, 04:34 PM
- Lo-Fi Version Time is now: 13th August 2025 - 03:52 PM
