Balancing flywheel/PP/clutch assembly, For my winter AX upgrades |
Chris Pincetich |
Jan 25 2007, 11:30 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I just received a 13lb flywheel in the mail yesterday from Dominic (IMG:style_emoticons/default/beerchug.gif)
I've read about the advantages of having the engine rotating mass balances, especially in race engines and those that see high rpms a lot. I am putting this med weight flywheel in my stock 1.7 for AX when I do a side-shift conversion in Feb. What's the best plan for installing this flywheel? Some say (i.e. Jake Raby) that if you can't dynamic balance every last bolt then don't bother. I'm thinking I want to send this mildly used flywheel for balancing. Would it be a waste of time and $$$ if the internals of my engine are not part of the balancing (i.e. crank)??? I can remove the clutch and PP (and bolts and gasket(?)) have this entire assembly sent for balancing...that seems like the best plan, but means having the car up on jack stands for the duration of the machine shop work (IMG:style_emoticons/default/dry.gif) Any referals to a competent shop in the SF Bay area close to Oakland are greatly appreciated! (IMG:style_emoticons/default/beerchug.gif) |
Chris Pincetich |
Jan 25 2007, 12:16 PM
High rpm = 4-6k for 1 minute. So, not too bad really.
What is $225? Complete engine balancing? |
Joe Ricard |
Jan 25 2007, 02:42 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
High rpm = 4-6k for 1 minute. So, not too bad really. What is $225? Complete engine balancing? Jake does have prices on some of his services. Just go to his site and find the balancing section. He explains what is all needed and to what degree of balance he will do. I know of a place about 100 miles from here that said he could do a balance for 150.00 but would not talk specifics like 10ths of gram and everything from the fan to the pressure plate. So he didn't pass my interview. You have straights in Autocross that are a minute long? I'm moving (IMG:style_emoticons/default/aktion035.gif) Hell I only get about 15 seconds of WOT on the straights of our local road course. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:29 AM |
