> Car won't start after warmed up
Hammy
post Jan 25 2007, 06:08 PM
mr. Wonderful
This is continued from the NARP board a while back. I'm still having the problem so I'm posting here
This is a carbed (dual Weber) 1.7
It happens like this:
I drive the car around town, gets up to full temp, stop at a store to go in real quick, come back out a couple minutes later and turn her over...
Crank, crank, crank, crank. Doesn't fire up
This happens sometimes, and then sometimes it doesn't happen, just fires right up. (IMG:style_emoticons/default/confused24.gif) Also, the car starts fine and easily when the engine is cold.
I can't tell if it's fuel related.
I don't know if it's getting too much fuel when trying to start?
I usually turn the engine over, and step the pedal down half way and it fires up. When this no start problem happens, no matter what I do with the gas pedal it doesn't fire. Sometimes I can get it to fire by holding the pedal down all the way and cranking forever and it'll start and run at like 100rpm, really slow like a tractor. I usually try and lightly tap the pedal to get it going strong, sometimes that'll work and sometimes it'll die.
Then I can't tell if it's not getting enough fuel when trying to start -
Because If I turn the engine over and don't touch the gas at all, it won't start. I normally have to push the gas down half way for a normal start.
Or is it ignition related? Could incorrect timing cause it to do this? Dying battery? Engine seems to turn over fine. I have 12.4 volts across the battery posts with the engine off.
Or Vapor lock? My fuel pump is just below the hell hole.
Also, I've checked for any pinched fuel hose/lines and can't find any. I wouldn't think it was that because once the engine gets started again, it runs perfectly fine. I'm just scared to turn it off.
Any help MUCH appreciated. This is killing me.
Twystd1
post Jan 26 2007, 07:00 AM
You don't want to know... really.....
It is probably running warmer due to the J Tube not being plugged...
FIX IT..... NOW.......... (please)
If the carb ain't closing all the way... You either have a linkage issue..
Or the butterfly (throttle blade) is sitting cocked in the carb base and not allowing the blade to close all the way. Or the throttle blade shaft is binding somewhere in it's bore.
Either way... You need to find out whats up and fix it.
I think "Engman" makes some block off plates for the J tube... Look him up in the vendor section and see if he has a remedy for that. Or simply fix your heater.
NOTE: After driving your car for twenty minutes or so. Pull over and pop your engine lid. Touch the carb bodywith your pinky. If it is so hot you are burning your finger. It's too dam hot. Usually carbs are relatively warm... NOT HOT..!!!!
They will get hotter if you wait a few minutes. (engine heat rising)
And if you burn your finger on it.... Well........ Thats your fault. I didn't say you had to try this..... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/alfred.gif)
YOU will have to figure it out. Don't send me the doctor bill like Aaron did. (IMG:style_emoticons/default/agree.gif)
NOTE 1: If you are really running it hard and pull over and check the carb body. It might even be cold to the touch.
NOTE 2. If you let sit and idle for ten minutes and try to touch the carb base... you better have a bandaid ready. Capiche?
Note 3: On an alcohol fuel race car. The carb will sometimes have ice on it when run hard........ no kidding.
Let us know what transpires on this... Okydoke?????
Hot carbs = BAD.
OH... And check your timing.
BUT FIRST.......
If using points. Check your your dwell with a dwell meter or re-set your points with a feeler gauge. I use a dwell meter only on points. Much more accurate.
(no feeler gauge for this guy if I can help it on used points)
BECAUSE YOU CAN'T SET CARBS CORRECTLY WITHOUT THE VALVES, POINTS AND TIMING BEING DEAD ON WITH NO INTAKE LEAKS.
Else your chasing your carb tuning forever......... Just wasting time.
Have I beat this to death enough?????
Cheers brother,
C
Hammy   Car won't start after warmed up   Jan 25 2007, 06:08 PM
904svo   Put a pressure gauge in line with the carb's, ...   Jan 25 2007, 07:51 PM
Hammy   Put a pressure gauge in line with the carb's,...   Jan 25 2007, 08:36 PM
914Sixer   What about the old fashion vapor lock?   Jan 25 2007, 09:10 PM
John   How long has it been since you rebuilt those carbs...   Jan 25 2007, 09:36 PM
LowGT   My 74 did that, you could actually see the carbs d...   Jan 25 2007, 09:53 PM
Twystd1   Well. Since the car does run and does start most ...   Jan 25 2007, 10:37 PM
SirAndy   sounds like fouled plugs .... check the carbs for...   Jan 26 2007, 12:04 AM
Hammy   I do have a heater valve right near the pump, but ...   Jan 26 2007, 01:01 AM
SirAndy   Also, putting the pedal to the floor and holding ...   Jan 26 2007, 01:10 AM
Hammy   Also, putting the pedal to the floor and holding...   Jan 26 2007, 01:13 AM
Scott Carlberg   How much is a carb rebuild gonna hit me? ..hav...   Jan 27 2007, 02:23 AM
Hammy   How much is a carb rebuild gonna hit me? ..ha...   Jan 27 2007, 02:53 AM
Twystd1   YUP... You just clarified what Andy, LowGT, John ...   Jan 26 2007, 01:31 AM
bondo   I rebuilt those carbs right before I sold the engi...   Jan 26 2007, 02:24 AM
bondo   Oh, and I know Hammy has the haynes weber book, be...   Jan 26 2007, 02:26 AM
Twystd1   If the carbs were just rebuilt.. And they work gre...   Jan 26 2007, 03:15 AM
Twystd1   It ain't terminal... Just giterdone...!...   Jan 26 2007, 03:17 AM
Hammy   Thanks Royce. didn't remember you rebuilt the ...   Jan 26 2007, 04:25 AM
Twystd1   It is probably running warmer due to the J Tube no...   Jan 26 2007, 07:00 AM
mudfoot76   If the carb ain't closing all the way... You...   Jan 26 2007, 07:43 AM
Paul Illick   Heat will also affect an already weak coil or cond...   Jan 26 2007, 07:42 AM
rhodyguy   i think clayton has nailed it. my 2.0 with 40s doe...   Jan 26 2007, 08:26 AM
Coy   I may be the worst mechanic on this board so take ...   Jan 26 2007, 06:28 PM
Twystd1   So have you fixed your J tube thingy? Let us know...   Jan 27 2007, 02:29 AM
Twystd1   Kewliobro... just wanna make sure you gitrdone......   Jan 27 2007, 03:08 AM
- Lo-Fi Version Time is now: 15th July 2025 - 11:56 AM
