> Ultimate side-shift linkage kit, Spy shots!
JWest
post Jan 25 2007, 07:53 PM
Here is a new product soon to be available from JWest Engineering - enjoy. (IMG:style_emoticons/default/idea.gif)
Mid_Engine_914
post Jan 26 2007, 11:19 AM
I think I need one of those - what's it do exactly? My broken one.
JWest
post Jan 26 2007, 11:46 AM
QUOTE(Mid_Engine_914 @ Jan 26 2007, 11:19 AM) *
Ah, it would work great with that broken one as the new support has its own bronze bushings and no longer uses that part of the casting.
Side shift only.
The advantage is that it is a true no-slop shift linkage. Due to the way that the side shift rods must angle as they rotate, just tightening up the stock bushings leads to binding unless they are hourglass shaped, and then they have a very small contact surface.
This systems takes out all the binding in rear and supports the rod on both sides of the cup.
The front (firewall) is taken care of by a nylon composite spherical bearing, allowing the off axis motion and low wear against the new chromoly shift tube.
I will be selling the kit for about $460.
There is some fabrication required. I did not want to force you to replace parts that you already have and drive the price up further.
You will have to cut the solid portion from the front of your own shift rod where it attaches to the shift head and weld this to the new shift tube. It is not critical (+/- 1/4" or more in length and no rotational alignment needed), so it is easy to complete.
I do not (at first) plan to supply the tube portion between the u-joints. This is the part that will be bent for a 4 cyl, straight for a 6 cyl, and longer for a V-8. Because the u-joints allow rotational re-alignment, this portion of the linkage is not as critical as the original design, so "close" is good enough in making this part, as long as it clears everything.
James Adams   Ultimate side-shift linkage kit   Jan 25 2007, 07:53 PM
Twystd1   Can you ball park us on how much the kit will cost...   Jan 25 2007, 08:13 PM
jim_hoyland   :confused: What is it ?   Jan 25 2007, 08:30 PM
effutuo101   Very nice! it will replace some of the old NLA...   Jan 25 2007, 08:32 PM
bondo   Very nice! it will replace some of the old NL...   Jan 25 2007, 08:36 PM
John   I like the dually supported rear shift rod. Will ...   Jan 25 2007, 08:48 PM
URY914   Looks like a new gear shift rod for a '67 Bus....   Jan 25 2007, 08:56 PM
boxstr   Looks like a Quantum Flux Capacitor, Nice improvem...   Jan 25 2007, 10:26 PM
914nerd   That's good My old quantum flux capacitor is a...   Jan 25 2007, 10:34 PM
ClayPerrine   Damn.. you beat me to it. Wes Hildreth and I have...   Jan 25 2007, 10:47 PM
James Adams   Damn.. you beat me to it. Wes Hildreth and I hav...   Jan 26 2007, 08:42 AM
ClayPerrine   Damn.. you beat me to it. Wes Hildreth and I ha...   Jan 26 2007, 08:58 AM
machina   James, Why does the rod have to stick out so far ...   Jan 26 2007, 09:33 AM
James Adams   James, Why does the rod have to stick out so far...   Jan 26 2007, 09:51 AM
BAM   James... Nice work, parts look great... Talk to...   Jan 26 2007, 10:03 AM
KaptKaos   Put me down for one! ...   Jan 25 2007, 11:21 PM
Justin Fischer   Cool, I've been waiting for this!!...   Jan 26 2007, 08:21 AM
Eric_Shea   Fucher :angry: Get your hands out of my wallet...   Jan 26 2007, 09:56 AM
rdauenhauer   so the idea is to replace the spagetti bender shif...   Jan 26 2007, 10:49 AM
BigDBass   Still dunno what it is but I want one. :D   Jan 26 2007, 11:06 AM
Trevorg7   Side Shift only or is one for a Tail in the works?...   Jan 26 2007, 11:13 AM
Mid_Engine_914   I think I need one of those - what's it do exa...   Jan 26 2007, 11:19 AM
James Adams   I think I need one of those - what's it do ex...   Jan 26 2007, 11:46 AM
ChrisNPDrider   Sweet. Nice boots! :beer2: James talked about...   Jan 26 2007, 11:36 AM
TROJANMAN   very pretty...... The CSOB that I am, I may actual...   Jan 26 2007, 11:47 AM
Eric_Shea   So, to answer my own question: -6 = yes, depends ...   Jan 26 2007, 12:05 PM
James Adams   So, to answer my own question: -6 = yes, depends...   Jan 26 2007, 12:22 PM
URY914   Does taking the slop out of the linkage relate to ...   Jan 26 2007, 12:22 PM
James Adams   Does taking the slop out of the linkage relate to...   Jan 26 2007, 12:24 PM
URY914   Does taking the slop out of the linkage relate t...   Jan 26 2007, 12:27 PM
rdauenhauer   Does taking the slop out of the linkage relate t...   Jan 26 2007, 01:09 PM
James Adams   [quote name='James Adams' post='854620' date='Jan...   Jan 26 2007, 01:41 PM
soloracer   James: Looks awesome! However, I bought the ...   Jan 26 2007, 01:46 PM
James Adams   James: Looks awesome! However, I bought the...   Jan 26 2007, 03:56 PM
rhodyguy   does the stock, late type rod boot at the firewall...   Jan 26 2007, 04:31 PM
James Adams   does the stock, late type rod boot at the firewal...   Jan 26 2007, 04:33 PM
rhodyguy   if this is a *fix* for the guys that have to run n...   Jan 26 2007, 04:40 PM
Aaron Cox   wow! very cool stuff!!! any fire...   Jan 26 2007, 05:38 PM
SirAndy   james, quick question: when will this be availabl...   Jan 26 2007, 05:50 PM
James Adams   james, quick question: when will this be availab...   Jan 26 2007, 07:47 PM
SirAndy   james, quick question: when will this be availa...   Jan 26 2007, 08:35 PM
Gint   :drooley: WOW! Awesome James!   Jan 26 2007, 06:47 PM
BarberDave   :trophy: James : I don't know if my heart c...   Jan 26 2007, 07:25 PM
James Adams   Here are a few more installed pics for your viewin...   Jan 27 2007, 09:05 PM
James Adams   qwerty   Jan 27 2007, 09:06 PM
James Adams   yuiop   Jan 27 2007, 09:09 PM
McMark   Does it bolt to the firewall with Riv-Nuts or did ...   Jan 27 2007, 09:38 PM
James Adams   Does it bolt to the firewall with Riv-Nuts or did...   Jan 27 2007, 10:08 PM
Eric_Shea   Eric, consider your place in line reserved too. ...   Jan 28 2007, 10:39 AM
James Adams   Eric, consider your place in line reserved too....   Jan 28 2007, 11:40 AM
James Adams   Eric, consider your place in line reserved too...   Jan 28 2007, 01:29 PM
Eric_Shea   Correct... if you read it here... it must be true ...   Jan 28 2007, 11:44 AM
ClayPerrine   James... can you put me in line too??? Thanks...   Jan 28 2007, 12:38 PM
James Adams   James... can you put me in line too??? Thanks...   Jan 28 2007, 01:31 PM
Eric_Shea   (put yourself in line... you can also name your pr...   Jan 28 2007, 01:16 PM
ClayPerrine   (put yourself in line... you can also name your p...   Jan 28 2007, 04:50 PM
Eric_Shea   :D all in fun. Can anybody weigh in here with...   Jan 28 2007, 02:28 PM
James Adams   Now available for ordering: Click here.   Mar 26 2007, 12:23 PM
michaelt55   James.. I have a 72 914 with a 215 V8 in it...the ...   May 3 2007, 03:43 PM
orange914   what kind of time and major parts removal is invol...   Jun 7 2007, 07:24 PM
James Adams   Michael and Orange, The linkage kit requires weldi...   Jun 7 2007, 07:44 PM
- Lo-Fi Version Time is now: 6th November 2026 - 03:28 PM
