Tire compounds to use for AX on loose asphalt and cold concrete?, what do you guys recommend? |
nine14cats |
Jan 24 2007, 01:27 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Since we lost Alameda Naval Station and its wonderfully grippy concrete as an AX venue, it appears the majority of our AX's will be at Candlestick's loose asphalt and beer bottle surface and at Marina's cold concrete. Which AX tires would work at these venues?
I have a set of Kumho V710's for AX that should work at Marina's concrete. Last year when Randal and I ran the 911 there even with 2 drivers we couldn't get any heat in the Goodyear slicks with R250 compounds. Andrew Blyholder had the same problem. I felt the tires on someone that was running the V710's and they were much hotter and stickier. For Candlestick, there is alot of loose debris and it's asphalt. The surface is generally cool there as well. Will the V710's work there or is it a waste and do I just run my heatcycled Victoracers from the track there? Or do Hoosiers work better on asphalt and beer bottles? What's the stickiest tire for the given conditions: 1. Cold ambient temp, loose asphalt 2. Cold ambient temp, concrete with gravel in the paddock area. Thanks, Bill P. |
grantsfo |
Jan 27 2007, 07:37 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Anyone else see Altamont as a venue for GGR. That has potential.
Randal |
Jan 27 2007, 12:05 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Anyone else see Altamont as a venue for GGR. That has potential. It will depend upon how much space is available AWAY from those walls. I've never forget when we used to run Dublin, i.e., the police site for high speed training. On one side there was this big concrete wall and one day a turbo lost it, skidded across a whole bunch of asphalt and just about kissed the wall. Scary. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:50 PM |
