ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
I've got a stock 2.0L distributor that is in need of rebuilding/refurbishing. I've looked through the vendor forum and didn't see anyone offering this service. Can anyone recommend someone to do this job?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ernie .... why do you think it needs rebuilding / refurbishing?
If it's sticky, you can use a can of carb cleaner and get the gunk out of the housing. The top plate (point plate) will come out with a couple of screws and expose the lower advance assembly. The rebuild of a dizzy is really limited to replacing the bushing in the housing, if and only if the points cam moves side to side a bunch. They will primarily clean / lube them and replace the points / condenser. They may replace the advance springs & vacuum can. They will not replace the trigger points unless they are broken / bad and that would be at extra cost (if they are still available). MotoParts as shown VAPEX in Gardena, CA A-1 Cardone - Philadelphia (usually this is what you get when you go to a local FlAPS) HiTest in Anaheim, CA Margus in Los Angeles Rotex in Gardena (not sure they do distributors) I would have to check on Monday if anyone in AZ (mainly Phoenix) is rebuilding distributors |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,418 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Ernie .... why do you think it needs rebuilding / refurbishing? If it's sticky, you can use a can of carb cleaner and get the gunk out of the housing. The top plate (point plate) will come out with a couple of screws and expose the lower advance assembly. The rebuild of a dizzy is really limited to replacing the bushing in the housing, if and only if the points cam moves side to side a bunch. They will primarily clean / lube them and replace the points / condenser. They may replace the advance springs & vacuum can. They will not replace the trigger points unless they are broken / bad and that would be at extra cost (if they are still available). I agree the key to rebuilding are the (2) required bushings per dizzy. A few years ago I got lucky and found (2) bushing rebuild kits complete with a bushing driver at a VW parts house going out of business. I rebuilt mine & gave the the other set to a friend. I wish I would have taken dimensions on the bushings. I am sure you can fabricate them, but try some of the local VW shops first. You may get lucky. Tom |
Lo-Fi Version | Time is now: 16th July 2025 - 12:39 PM |
