> before I cut out more... what is the best route, to repair this? Thanks
snflupigus
post Jan 28 2007, 06:21 PM
here's where I'm at so far, started a long long time ago in a galaxy far far away. I just bought a Lincoln Elec 150 last week that should do the job fine. My first thoughts practicing with that are that I seem to have picked up welding fairly easily, I'm not sure what all the fuss is about... I've practiced on scrap I've cut out from the car, but welding them back together, exhaust pipe, angle iron... none of it has been too difficult. Time to get some gas before I touch the car though.
Anyway, I will probably remake a new body cart with steel stock... one that I can bolt on adapters to hold the suspension mounting points stable as I think that is going to be a good idea if i take out anymore. I think before I do cut the frame I will add in tangerines rear pickup reinforcement and inner console reinforcements as well as a long and rear chassis stiffening kit.
I just dont want the car to flex... after hammer back down both of my front jack donuts my passenger side is still about 1/8 to a 1/4 of an inch off the wooded cart. It may be that its just leaning because its really resting on the center under the tunnel but it could be that the car is tweeked a bit. I think i was 1.4 inch off between the top of the windsheild and the rollbar when i measured those distances. I dont know what they were but thats what the difference was.
comments suggestions. I actually feel like i'm getting closer to sending it to paint. even thought i know im still pretty far away. (IMG:style_emoticons/default/smile.gif)
Thanks
(IMG:http://www.snflupigus.com/pics/914/hole2.jpg)
click here for larger of that one
(IMG:http://www.snflupigus.com/pics/914/p.jpg)
(IMG:http://www.snflupigus.com/pics/914/d.jpg)
Crazyhippy
post Jan 28 2007, 09:54 PM
Insert witty comment here...
An "assistant" will make life much easier. Hold a piece of metal over the back side of the hole, and draw around it w/ a sharpie to get the exact dimensions figured out. Cut it out, and fit untill it's perfect (take your time here, it makes the welding 100% easier).
Then you and your assistant hold the piece where it will live, and tack. Hold the top, tack the bottom and sides... Take a hammer and ensure things are right where you want. Can hold the hammer against the edge to keep the metal in line and tack next to it if needed. tack one side again, then the other, work around the metal, and dont put too much heat in one spot. If you need to adjust, use the hammer.
The pass. firewall might be easier in 2 pieces, and when all is done you grind the welds, and no one will know.
Slow, methodical, and keep the heat spread out.
- Lo-Fi Version Time is now: 1st August 2025 - 12:38 PM
