jgara962 |
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California ![]() |
My weekend project is to remove the backpad and rubber pad behind it. So far so good - the two combined weight 26 lbs! I'm going to put down some Dynamat Extreme and then lay a Morph carpet kit over the top.
One question. Do I need to remove all of the glue that is stuck to the firewall from the original pad, or do you think I can just lay the Dynamat over it? What should I use? So far I've tried Goof Off and a razor blade scrapper, but that's going to take a while and I already have a buzz going (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
highways |
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 ![]() |
You might as well do the center area or you havent really done that much good by just doing the sides behind the seats. You really need to cover as much area as possible. You will still have noise infiltration in the center unless covered. Next time I would recommend using Phat Mat. One normal size roll would be enough to cover all of the back area with more left over. CCLINPHATMAT Got a link for the Phat Mat's? I looked and only found this... derogatory 914 joke? Or just the way you do it oregon? May the reader decide... (IMG:style_emoticons/default/golfer.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 10:45 AM |
