| Air_Cooled_Nut |
Jan 29 2007, 01:13 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
http://www.icbm.org/erkson/personal/porsch...alve_adjust.htm
I got under my car to perform my first in-car valve adjustment (my very first 914 valve adjustment was with the engine out of the car). Wow, was I baffled as what to exactly do (IMG:style_emoticons/default/confused24.gif) I didn't find it easy to adjust the valves with the tires and heat exchangers in the way and my neck and wrists were put into unnatural, fatigueing positions, along with limited visibility. So after some pondering and inspecting, this is what I came up with. The manuals and web sites do a poor job explaining EXACTLY what needs to be done for an in-car valve adjust as far as GETTING to the valves. This should allow beginning 914 owners a very good path to getting to their rocker assemblies with minimal contortions, bumped/scraped hands, and neck cramping. It is assumed the person knows how to adjust valves, they just need a way to get in there. It's a quick procedure as well; removing the heating system parts actually goes very quickly thanks to its simplicity (IMG:style_emoticons/default/clap56.gif) Hope it helps... (IMG:style_emoticons/default/type.gif) |
| Cap'n Krusty |
Jan 29 2007, 11:17 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Nice. Detailed. Complete. TOO BAD IT'S THE HARD WAY! You can read the same BS on the Bird Board. Go here to see how the real wrenches do it:
http://www.914club.com/bbs2/index.php?showtopic=28758 Once you've done it my way, you'll laugh at the very thought of doing it the other way. The Cap'n |
| Air_Cooled_Nut |
Jan 30 2007, 11:32 AM
Nice. Detailed. Complete. TOO BAD IT'S THE HARD WAY! You can read the same BS on the Bird Board. Go here to see how the real wrenches do it: http://www.914club.com/bbs2/index.php?showtopic=28758 Once you've done it my way, you'll laugh at the very thought of doing it the other way. The Cap'n Actually, after reading your method from the "original" 914club site -- as well as what was posted on Pelican -- and what the shop manuals instruct, I don't consider your method any simpler by a significant magnitude and you still fail to instruct the person how to get to the darn valves in the first place! (IMG:style_emoticons/default/bootyshake.gif) If someone doesn't want to remove the heater parts, fine, it's not necessary. But for me it made life WAY easier in adjusting the forward valves. Maybe laying on my back on a creeper isn't the way to do this? I think positioning the dizzy at #1 firing position and then using the marked flywheel as a guide is more accurate than watching the rockers move as you spin the tire. This valve adjusting method is very simple, accurate, requires no guess-work, and would take no more time (and probably less) than your "spin the tire on the Porsche" method. As for the insulting comment about "real wrenches", this [valve adjusting] method was told to me by two certified VW dealership mechanics of over 20 years experience each (one of which had his own independent shop as well), and is used by other VW nuts with far more experience than you. I've used it on my dub for years as well. Get off your high horse, you're not as great as you think. |
Air_Cooled_Nut 914 newbie valve adjusting help is here. Jan 29 2007, 01:13 AM
So.Cal.914 Cool thread, very clear. Jan 29 2007, 02:15 AM
Lawrence Very well done. :) Jan 29 2007, 02:59 AM
cooltimes Thank you for posting this tech procedure.
It is ... Jan 29 2007, 09:27 PM
SGB Alwayswelcome information. I don't know how ma... Jan 29 2007, 09:53 PM
Carlitos Way I think that's a wonderful way to do the valve... Jan 29 2007, 10:30 PM
Cap'n Krusty
[quote name='Cap'n Krusty' post='855988' date... Jan 31 2007, 07:07 PM
PinetreePorsche I haven't tried both this method and The Cap... Jan 30 2007, 10:42 AM
Air_Cooled_Nut
...(And someone's suggestion of using a rag, ... Jan 30 2007, 11:33 AM
BigDBass Thanks for the how-to.
As someone who has yet to a... Jan 30 2007, 11:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th November 2026 - 12:01 PM |
