> couple quick CHT gauge questions, sender and gauge lighting
Hammy
post Jan 13 2007, 02:46 AM
mr. Wonderful
So I received my Dakota Digital CHT gauge today (IMG:style_emoticons/default/mueba.gif) Looks great
Anyways, I have some questions and I want some answers (IMG:style_emoticons/default/cool_shades.gif)
1 - The gauge sender washer/loop/ring end is just a hair too small to slide/thread onto the spark plug. I did order the correct size, 14mm, but it seems still just a tad too small. Is it ok to open the hole up just a little tiny bit more? It seems highly doubtful it'd be a problem, but just checking.
2 - Does the sender ring replace the spark plug washer? If not, does it go in front of the washer, or in between the washer and plug?
3 - The gauge has a night dimming feature so that when the headlights are turned on, it dims the output of the gauge (it's a digital display). I notice there are some unhooked male spade connectors in the center tunnel wiring harness, behind the shifter. They have a plastic protector box around them. What are they for? I think I've read that they're for center console gauge lights, correct?
Thanks for any help
eeyore
post Jan 30 2007, 06:56 PM
If you get the 12mm sender, you get a choice between 10, 14, & 18, or something like that.
They tell to to NOT cut the wire, but the interesting thing is the sender is 2 pieces. A short (1 foot) lead on the sender ring itself, then the remain length of wire. All bolted together with itty-bitty bolts and nuts. The gauge has adjustments for sender temp ranges, but not sender wire lengths.
Hammy   couple quick CHT gauge questions   Jan 13 2007, 02:46 AM
Dave_Darling   #3 -- The wires are for all of the center console ...   Jan 13 2007, 12:24 PM
Aaron Cox   bump for hammy to get some answers on CHT   Jan 16 2007, 01:24 PM
McMark   1- Yep, I've seen people grind them. I can...   Jan 16 2007, 01:27 PM
Rand   File the inside with a round file just enough so y...   Jan 16 2007, 01:29 PM
SLITS   Just thread the ring on like you were screwing the...   Jan 16 2007, 01:55 PM
Hammy   Thanks AA for the bump I tried to thread it ont...   Jan 16 2007, 05:02 PM
spunone   Hammy which gauge did you buy and how long where t...   Jan 16 2007, 05:18 PM
Hammy   Hammy which gauge did you buy and how long where ...   Jan 16 2007, 05:29 PM
spunone   Wonder if you can put on a switch and use another ...   Jan 16 2007, 06:22 PM
Rand   Wonder if you can put on a switch and use another...   Jan 16 2007, 06:24 PM
Hammy   Wonder if you can put on a switch and use anothe...   Jan 16 2007, 09:27 PM
spunone   Talked to the fellas at Dakota Dig nope can't...   Jan 30 2007, 02:40 PM
Hammy   Talked to the fellas at Dakota Dig nope can...   Jan 30 2007, 04:31 PM
spunone   They say you can cut it just can't add to it a...   Jan 30 2007, 04:34 PM
Rand   My info said not to cut it at all... Don't sho...   Jan 30 2007, 05:05 PM
Aaron Cox   resistance changes with wire length right? so if t...   Jan 30 2007, 05:33 PM
spunone   Ok so why did 1 sales scum then a tech guy say you...   Jan 30 2007, 05:57 PM
spunone   Oh yeah I think they made the sender for a vw bus   Jan 30 2007, 05:58 PM
Mark Garriott   If you get the 12mm sender, you get a choice betwe...   Jan 30 2007, 06:56 PM
- Lo-Fi Version Time is now: 16th April 2026 - 08:33 PM
