> Guys, quick!, CV JOINTS
alpha434
post Jan 30 2007, 08:25 PM
My member number is no coincidence.
Is it possible for a CV joint to slip out of the carrier without breaking? Mine is supported by just the boot right now, and I'm starting a new job tomorrow at 6am.
I need to know so I'll know exactly what I'm in for when I go to get my car tonight.
(IMG:style_emoticons/default/blink.gif)
Thanks!
alpha434
post Jan 30 2007, 10:00 PM
Additionally, I couldn't remove the CV because I don't have a jack to get the rear end in the air. Or at least not a jack that I can carry 7 blocks. God. I need to find me a scissor jack to keep in that car. It gives me more goddamn problems.
You'd think that at 24 bucks an hour, I could just buy a Boxster and be done with the damn thing.
alpha434   Guys, quick!   Jan 30 2007, 08:25 PM
Lawrence   I would have to say... no. Did you rebuild your a...   Jan 30 2007, 08:29 PM
alpha434   Nope. The axles are as they were from previous own...   Jan 30 2007, 08:31 PM
Lawrence   I was under the assumption, silly me, that you wou...   Jan 30 2007, 08:37 PM
Brando   Screws? The only way the axle would slip out of t...   Jan 30 2007, 08:37 PM
Lawrence   Brando is on target. :agree:   Jan 30 2007, 08:39 PM
Andyrew   there could be a hairline crack in the cage...   Jan 30 2007, 08:40 PM
alpha434   I don't have the car handy. The problem is t...   Jan 30 2007, 08:46 PM
Brando   Get the rear end in the air with some daylight. T...   Jan 30 2007, 08:52 PM
alpha434   I *did* check the bolts. They seemed somewhat tigh...   Jan 30 2007, 08:53 PM
alpha434   Dude, Brando. Gotta have it running by 6 am tomorr...   Jan 30 2007, 08:54 PM
Lawrence   I'm guessing broken CV joint. if the bolts we...   Jan 30 2007, 08:54 PM
Lawrence   Do you think that would be audible over engine n...   Jan 30 2007, 08:56 PM
TROJANMAN   chris, post on the local board. someone near may...   Jan 30 2007, 09:01 PM
Brando   It should/ would be audible over engine noise with...   Jan 30 2007, 09:04 PM
alpha434   F#in A! It is COLD!!! Jesus. It ...   Jan 30 2007, 09:57 PM
Lawrence   Retaining clip is probably broken. Open it up and...   Jan 30 2007, 09:59 PM
alpha434   Additionally, I couldn't remove the CV because...   Jan 30 2007, 10:00 PM
alpha434   I'll make a point of getting that clip out. Wh...   Jan 30 2007, 10:02 PM
Andyrew   You would think. Go buy a mini jack, not a scisso...   Jan 30 2007, 10:03 PM
alpha434   Damn it! That car is lucky that I'm in lov...   Jan 30 2007, 10:05 PM
alpha434   Yeah, I agree with you, andrew. I don't trust ...   Jan 30 2007, 10:09 PM
John   If you are really going to get it done tonight in ...   Jan 30 2007, 10:16 PM
Crazyhippy   It usually takes a press to install that retaining...   Jan 30 2007, 10:21 PM
John   I never needed a press.   Jan 30 2007, 10:44 PM
alpha434   UGh. RSR CVs ARE titanium. They are soooo much ea...   Jan 30 2007, 11:14 PM
Brando   Update us, how har along did ya get?   Jan 31 2007, 10:28 AM
alpha434   How do I get the cv off the wheel hub? The bolts a...   Jan 31 2007, 01:58 PM
Brando   The CV bolts are on the inboard side of the wheel....   Jan 31 2007, 02:20 PM
Lawrence   I'm not sure how you know it's the circlip...   Jan 31 2007, 02:25 PM
alpha434   Yeah. Thanks, Brando. The mount itself should be ...   Jan 31 2007, 02:28 PM
Brando   Chris, this should help some:   Jan 31 2007, 03:16 PM
alpha434   Perfect. Thanks. It's 18 degrees outside!   Jan 31 2007, 03:20 PM
- Lo-Fi Version Time is now: 4th March 2026 - 06:05 PM
