| alpha434 |
Jan 30 2007, 08:25 PM
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Is it possible for a CV joint to slip out of the carrier without breaking? Mine is supported by just the boot right now, and I'm starting a new job tomorrow at 6am.
I need to know so I'll know exactly what I'm in for when I go to get my car tonight. (IMG:style_emoticons/default/blink.gif) Thanks! |
| John |
Jan 30 2007, 10:44 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
QUOTE It usually takes a press to install that retaining clip. This is not an easy side of the road repair. A new axle makes life 1000% easier. I never needed a press. |
alpha434 Guys, quick! Jan 30 2007, 08:25 PM
Lawrence I would have to say... no. Did you rebuild your a... Jan 30 2007, 08:29 PM
alpha434 Nope. The axles are as they were from previous own... Jan 30 2007, 08:31 PM
Lawrence I was under the assumption, silly me, that you wou... Jan 30 2007, 08:37 PM
Brando Screws?
The only way the axle would slip out of t... Jan 30 2007, 08:37 PM
Lawrence Brando is on target. :agree: Jan 30 2007, 08:39 PM
Andyrew there could be a hairline crack in the cage... Jan 30 2007, 08:40 PM
alpha434 I don't have the car handy.
The problem is t... Jan 30 2007, 08:46 PM
Brando Get the rear end in the air with some daylight.
T... Jan 30 2007, 08:52 PM
alpha434 I *did* check the bolts. They seemed somewhat tigh... Jan 30 2007, 08:53 PM
alpha434 Dude, Brando. Gotta have it running by 6 am tomorr... Jan 30 2007, 08:54 PM
Lawrence I'm guessing broken CV joint. if the bolts we... Jan 30 2007, 08:54 PM
Lawrence
Do you think that would be audible over engine n... Jan 30 2007, 08:56 PM
TROJANMAN chris,
post on the local board. someone near may... Jan 30 2007, 09:01 PM
Brando It should/ would be audible over engine noise with... Jan 30 2007, 09:04 PM
alpha434 F#in A!
It is COLD!!! Jesus.
It ... Jan 30 2007, 09:57 PM
Lawrence Retaining clip is probably broken.
Open it up and... Jan 30 2007, 09:59 PM
alpha434 Additionally, I couldn't remove the CV because... Jan 30 2007, 10:00 PM
alpha434 I'll make a point of getting that clip out. Wh... Jan 30 2007, 10:02 PM
Andyrew You would think.
Go buy a mini jack, not a scisso... Jan 30 2007, 10:03 PM
alpha434 Damn it! That car is lucky that I'm in lov... Jan 30 2007, 10:05 PM
alpha434 Yeah, I agree with you, andrew. I don't trust ... Jan 30 2007, 10:09 PM
John If you are really going to get it done tonight in ... Jan 30 2007, 10:16 PM
Crazyhippy It usually takes a press to install that retaining... Jan 30 2007, 10:21 PM
alpha434 UGh.
RSR CVs ARE titanium. They are soooo much ea... Jan 30 2007, 11:14 PM
Brando Update us, how har along did ya get? Jan 31 2007, 10:28 AM
alpha434 How do I get the cv off the wheel hub? The bolts a... Jan 31 2007, 01:58 PM
Brando The CV bolts are on the inboard side of the wheel.... Jan 31 2007, 02:20 PM
Lawrence I'm not sure how you know it's the circlip... Jan 31 2007, 02:25 PM
alpha434 Yeah. Thanks, Brando.
The mount itself should be ... Jan 31 2007, 02:28 PM
Brando Chris,
this should help some:
Jan 31 2007, 03:16 PM
alpha434 Perfect. Thanks.
It's 18 degrees outside! Jan 31 2007, 03:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 06:05 PM |
