Rear Trunk Latch Problem, OMFG |
mrhurtalot |
Feb 3 2007, 03:58 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) so. i REALLY need to get into my rear trunk. problem is, it wont open. PO removed the lock and place an electric latch and put the cool porsche reflector on the back. are there any alternative ways into the trunk? (access hole on the underside? lmao) (IMG:style_emoticons/default/huh.gif) the wiring seems to be fine and all connections are fine. i even have the JWEST fuse panel with no blown fuses. replaced the inline fuse, POP! about 3 fuses. and then nothing. ANY IDEAS? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
mrhurtalot |
Feb 3 2007, 08:42 PM
ugh... two hours of work. and nothing...
the hanger doesnt work because the lever needs to be pushed down. hard. im getting so frustrated. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) i have thought about busting out one of the tail lights. and dremeling (IMG:style_emoticons/default/sawzall-smiley.gif) my way into the trunk. (IMG:style_emoticons/default/chair.gif) anyone got a source for tail lights? or even better. another suggestion? Attached thumbnail(s) |
SirAndy |
Feb 3 2007, 08:52 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the hanger doesnt work because the lever needs to be pushed down. hard. aha, yes, the solenoid. hanger works on the stock latch. as mentioned above, put a bunch of extensions together and try to undo the bolts that hold the latch to the body. 10mm socket, if still stock ... (IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 6th June 2024 - 08:17 AM |
