is my engine toast?, help with crazy noises? |
runfaster |
Feb 3 2007, 11:55 PM
Newbie Group: Members Posts: 47 Joined: 29-March 06 From: oregon Member No.: 5,789 |
i bought a 2.0 and i took my 1.7 out to see what kind of running shape the 2 liter was in....it had some issues, so i went to put the 1.7 back in and when i cranked it up i was getting this crazy bearing squeal that sounded like it was comming from the alternater or around that area followed by a huge knocking and clunking sound from head on the driver side.
i dropped the engine and swapped out with a spare alternator and when put it back in and cranked it i still had the same noises. i dropped it again and checked the starter and new clutch kit. they look fine. i did notice that when i spin the flywheel, #3 and #4 rockers seem to be moving in and out properly, but #1 and #2 i only get #2 exhaust moving and nothing else.... does this make any sense? if not i can try to explain differently.... |
So.Cal.914 |
Feb 3 2007, 11:59 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
If I am reading you right...it dosen't sound good. Pull rocker assembly
and head off and inspect. Pics. |
runfaster |
Feb 4 2007, 12:02 AM
So.Cal.914 |
Feb 4 2007, 09:56 AM
If I am reading you right...it dosen't sound good. Pull rocker assembly and head off and inspect. Pics. that was what i was thinking.....what should i see if there are problems? Bent metal, broken parts...you'll know. I hope I am wrong. |
jim_hoyland |
Feb 4 2007, 10:50 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Your description of the sound/noise reminds me of when the cam in my 1.8 cam undone.
Lo-Fi Version | Time is now: 9th June 2024 - 10:16 PM |
