runfaster
Feb 3 2007, 11:55 PM
i bought a 2.0 and i took my 1.7 out to see what kind of running shape the 2 liter was in....it had some issues, so i went to put the 1.7 back in and when i cranked it up i was getting this crazy bearing squeal that sounded like it was comming from the alternater or around that area followed by a huge knocking and clunking sound from head on the driver side.
i dropped the engine and swapped out with a spare alternator and when put it back in and cranked it i still had the same noises. i dropped it again and checked the starter and new clutch kit. they look fine.
i did notice that when i spin the flywheel, #3 and #4 rockers seem to be moving in and out properly, but #1 and #2 i only get #2 exhaust moving and nothing else....
does this make any sense? if not i can try to explain differently....
So.Cal.914
Feb 3 2007, 11:59 PM
If I am reading you right...it dosen't sound good. Pull rocker assembly
and head off and inspect. Pics.
runfaster
Feb 4 2007, 12:02 AM
QUOTE(So.Cal.914 @ Feb 3 2007, 09:59 PM)
that was what i was thinking.....what should i see if there are problems?
So.Cal.914
Feb 4 2007, 09:56 AM
QUOTE(runfaster @ Feb 3 2007, 10:02 PM)
Bent metal, broken parts...you'll know. I hope I am wrong.
jim_hoyland
Feb 4 2007, 10:50 AM
Your description of the sound/noise reminds me of when the cam in my 1.8 cam undone.
QUOTE(So.Cal.914 @ Feb 4 2007, 07:56 AM)
runfaster
Feb 4 2007, 12:30 PM
well, i guess i am about to further my knowledge of the type 4. what was i thinking when i bought this pos.......never ending......
oh by the way for all you that helped me out with my rear main seal issues- i thank you......
i used gear oil around the seal before installing the flywheel....it seemed to stop leaking before my engine internals crapped out on me......
thanks......
911quest
Feb 4 2007, 12:34 PM
did you bend a push rod tube? it's possible the push rod poped out of the lifter.
