Do you cheat? |
Do you cheat? |
grantsfo |
Feb 6 2007, 07:35 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I couldn't resist creating this anonymous poll! (IMG:style_emoticons/default/biggrin.gif)
DanT |
Feb 7 2007, 12:05 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
and that is exactly what is wrong with our current rules....
too many loop holes when it comes to lightening. Only 20 points to strip your interior.... no padding, no door panels, no back pad, no carpet...20 points to do what you folks did,,,,,20 points. there needs to be more granularity with respect removing weight, DOT R tires, and a few other items. 100WR RA1s should not get the same points as 710s. removing your windshield and or the entire windshield frame should be points....but it isn't right now. It helps when you (royal you) has a major part in writing the new rules....doesn't it? (IMG:style_emoticons/default/dry.gif) |
grantsfo |
Feb 7 2007, 01:18 AM
too many loop holes when it comes to lightening. Only 20 points to strip your interior.... no padding, no door panels, no back pad, no carpet...20 points to do what you folks did,,,,,20 points. there needs to be more granularity with respect removing weight, DOT R tires, and a few other items. 100WR RA1s should not get the same points as 710s. removing your windshield and or the entire windshield frame should be points....but it isn't right now. Booyah!!! (IMG:http://www.914club.com/bbs2/uploads/monthly_02_2007/post-478-1170563107.jpg) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:41 PM |
