To prime or not to prime... |
1bad914 |
Feb 7 2007, 06:43 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
I am assembling a 1911 motor with hydraulic lifters, I really don't want to debate the use of them, I am giving them a try no matter what. (IMG:style_emoticons/default/biggrin.gif)
My question is, should I prime the lifters or not, I have heard that you should soak them in oil, then pump them in oil, then I read that you should put them in dry...not sure what to do. Also, the push rods are different, they look suspiciously like Type I chromoly push rods. I bought this motor in a partially assembled state, tore it all down and started from scratch. Any other tips for hydros? |
Katmanken |
Feb 7 2007, 07:37 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Fill them up. They need to be pumped up to operate and it will be a little hard to get the valves adjusted without oil in them. Not only that, but they make expensive noises when dry and the pushrods can slip out of the lifters and damage them.
Yes, If I recal right, the the hydro pushrod tips are different, and maybe the length. Try a Bus or VW site. Ken |
Lo-Fi Version | Time is now: 1st June 2024 - 12:15 AM |
