Megasquirt question.... |
Joe Bob |
Feb 6 2007, 08:59 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
If you are running dual throttle bodies...where can you put a "fifth" injector for cold start enrichment or is there a setting in the software I'm missing? My 2.2 runs like crap until 210F.....which is about 5 miles at cruising speed.
smdubovsky |
Feb 8 2007, 12:51 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Got ITBs on my 911. No easy way to add air for idle. I've always thought of using one of the stepper motor screw drive type IACs, removing the IAC part, and mounting it so the screw drive pushed on the throttle linkage. Closed loop idle control but its ALOT of work. One valve and 4 tubes would work, but you'd have to balance them. You could also do a 'fast idle' solenoid to push on the linkage.
Easier to add some ign advance below idle. Say your running 10deg at 1000rpm. Put 15deg in the <=900rpm bins. If the motor rpm sags, the extra advance will help out. Of course you need to play w/ the # to find a safe and effective amount. SMD |
Lo-Fi Version | Time is now: 6th June 2024 - 12:08 PM |
