> Swapping engines for Dummies, flywheel question & thermostat coil question
computers4kids
post Feb 8 2007, 10:11 PM
Love these little cars!
1. I should know the answer to this...but I don't.
Pulling my 1.8 FI motor which only has 300 miles on a new 6 spring clutch and resurfaced flywheel.
I have a 2ltr going in. Can I use the 1.8 flywheel (on the my 2ltr transplant as is (I know the clutches are the same)?
Wasn't too sure if the flywheels are balanced to the motor.
2. There is a coil thermostat that bolts on the underside of the motor near where the clutch cable wheel resides. Both of my engines, the coil cable has frayed and broken and the cable is just dangling. Where does the end of the cable suppose to connect to? I can find where it once connected. How necessary is this? If it is, can you just add a little cable and connect it to whereever?
Thanks,
John
post Feb 8 2007, 10:38 PM
member? what's a member?
Geez,
I'm sorry.
On topic:
1. Yes the 1.8 Flywheel and clutch are the same as the 2.0 parts. You can balance the flywheel with the crank, but typically they are balanced alone.
When shimming the flywheel, there are ALWAYS a total of 3 shims. Never less and never more.
2. The thermostat cable wraps around the thermostat pulley and is routed straight up to the flappers that reside inside the cooling tin. The flappers are under spring tension, so if the cable is broken they should be in the "hot" position. The thermostat expands (lengthens) when it gets hot and allows the flappers to move to the "hot" position.
When the flappers are in the "hot" position, it diverts more air to the oil cooler.
If you grab the flapper crossbar, it should rotate and you should see the frayed end of the cable extending down toward the engine tin. There is a hole which aligns with the thermostat pulley.
I would recommend replacing the broken cable.
Good luck with that.
- Lo-Fi Version Time is now: 8th July 2025 - 09:36 PM
