computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
1. I should know the answer to this...but I don't.
Pulling my 1.8 FI motor which only has 300 miles on a new 6 spring clutch and resurfaced flywheel. I have a 2ltr going in. Can I use the 1.8 flywheel (on the my 2ltr transplant as is (I know the clutches are the same)? Wasn't too sure if the flywheels are balanced to the motor. 2. There is a coil thermostat that bolts on the underside of the motor near where the clutch cable wheel resides. Both of my engines, the coil cable has frayed and broken and the cable is just dangling. Where does the end of the cable suppose to connect to? I can find where it once connected. How necessary is this? If it is, can you just add a little cable and connect it to whereever? Thanks, |
computers4kids |
Thanks for all the advice. Found quite a bit of old threads on the workings of the cooling flaps--these motors just continue to amaze me.
Thanks again |
Lo-Fi Version | Time is now: 8th July 2025 - 08:23 PM |
