> Swapping engines for Dummies, flywheel question & thermostat coil question
computers4kids
post Feb 8 2007, 10:11 PM
Love these little cars!
1. I should know the answer to this...but I don't.
Pulling my 1.8 FI motor which only has 300 miles on a new 6 spring clutch and resurfaced flywheel.
I have a 2ltr going in. Can I use the 1.8 flywheel (on the my 2ltr transplant as is (I know the clutches are the same)?
Wasn't too sure if the flywheels are balanced to the motor.
2. There is a coil thermostat that bolts on the underside of the motor near where the clutch cable wheel resides. Both of my engines, the coil cable has frayed and broken and the cable is just dangling. Where does the end of the cable suppose to connect to? I can find where it once connected. How necessary is this? If it is, can you just add a little cable and connect it to whereever?
Thanks,
StratPlayer
post Feb 9 2007, 10:35 AM
StratPlayer
So where does this spacer (#3) fit into things. I never see anyone mentioning this spacer.
- Lo-Fi Version Time is now: 8th July 2025 - 09:03 PM
